ChevyBoy Posted March 26, 2007 Report Posted March 26, 2007 definitely scrape the paint away from the grounds then. and since your body is your frame, ground it in the trunk somewhere and make it less than 3' long. Quote
bass 4 love Posted March 26, 2007 Author Report Posted March 26, 2007 (edited) definitely scrape the paint away from the grounds then. and since your body is your frame, ground it in the trunk somewhere and make it less than 3' long. Cool... also how would you hook up two Capacitors? off of 1 battery or is that Impossible? Edited March 26, 2007 by bass 4 love Quote
bass 4 love Posted March 26, 2007 Author Report Posted March 26, 2007 Cool... also how would you hook up two Capacitors? off of 1 battery or is that Impossible? NVM tat pick wrong 1 Quote
Slinky Posted March 26, 2007 Report Posted March 26, 2007 in your sitiatio, i wouldnt hook up 2 caps. maybe one. Quote DD M4 Rockford Fosgate P500-4 SoundQubed HDC415 w carbon fiber cap 2 Rockford Fosagate T1675-S XS Power D3400 Under Hood XS Power D5100 in rear Michael Singer 200A Alt Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
bass 4 love Posted March 26, 2007 Author Report Posted March 26, 2007 in your sitiatio, i wouldnt hook up 2 caps. maybe one. Well i got some rockford amps on the way for my HIGH'S Quote
dleccord Posted March 26, 2007 Report Posted March 26, 2007 Hummmm, I'll try that.....any other solutions That's the only solution. Only way to go. Either that or your RCA connections are bad. What ground are you talking about? Your amps should be grounded to the frame, and also keep your power and grounds away from your signal wires. Now your head unit ground can cause whining on all channels since it'll transmit through everything. Mine was doing that a while back. I just took it down and grounded it on the frame with my amps, problem solved You don't have to keep your power wires away from your signal wires. I run all my wires on the same side and next to each other, never had noise issue. Yes, you need to thoroughly clean and sand the grounding point. Make it as good as new metal. That should help a loot New metal as in shiny metal:) Quote refs: chode69, superduper
