Basshead08 Posted July 10, 2009 Report Share Posted July 10, 2009 Alright cool! Thought you had to do the build with only one sub for the bet. System tear out has begun...Out with the old i have a iq of 128 i graduated at the top of my class tell me how im reatrded you are the 1 thats dumb as hell you can't even spell Look at the underlined text hahahahahahahaha I think of it as the virgin losing the virginity technique not just jumping in to it, and pounding away, but going at it slowly over time, to get to that full extreme Link to comment Share on other sites More sharing options...
doug118 Posted July 10, 2009 Author Report Share Posted July 10, 2009 ok dimensions are 18" high 36/48" wide (strut towers/back of trunk) 30/36" long (top/bottom of seat) and yes the bet is for a single sub but if when I'm ready to buy an amp and there happens to be a t4k for under $1k for sale I'm buying it then just saying fuck it and get 2 subs 2001 Tahoe. Huge front stage and 55+ substage http://www.stevemeadedesigns.com/board/topic/196418-another-tahoe-build-huge-front-stage-and-155-substage/ Link to comment Share on other sites More sharing options...
doug118 Posted July 10, 2009 Author Report Share Posted July 10, 2009 I also need help figuring out how to make a box with sub forward and port through the rear deck. idk if I want to do a normal slot port or 2 aero ports through the stock speaker holes. either way I'm not sure how to place/build the port 2001 Tahoe. Huge front stage and 55+ substage http://www.stevemeadedesigns.com/board/topic/196418-another-tahoe-build-huge-front-stage-and-155-substage/ Link to comment Share on other sites More sharing options...
RamenNoodles Posted July 10, 2009 Report Share Posted July 10, 2009 explorers meter extremely well, watch what you bet. Though he is running sealed and that is a very big disadvantage. I have seen explorers with 2) 15s do 155s in ported box. Jacob from sundown has a loud as fawk exploder. His 1 15 was doing like 152s or 153s Diablo Audio Technologies Fi Car Audio Ascendant Audio Link to comment Share on other sites More sharing options...
Ben Building Posted July 10, 2009 Report Share Posted July 10, 2009 any other input?You have a shot at glory here. If your 1 sub is even in the same realm sound-wise as the Ex, then you are going to look like a hero. If he beats you, then it's because he has 4 15s and a truck.Explorers are notoriously loud for bass. Even if you put 2 crappy 12s in an Ex, they are probably going to sound like somebody's 15s. The good thing is that you have a Honda, which is built pretty tight. Does your boy's truck "look" louder than this? Link to comment Share on other sites More sharing options...
Ben Building Posted July 10, 2009 Report Share Posted July 10, 2009 I also need help figuring out how to make a box with sub forward and port through the rear deck. idk if I want to do a normal slot port or 2 aero ports through the stock speaker holes. either way I'm not sure how to place/build the portUse the aero ports instead of a slot port for added port efficiency. You tune ports by making them longer or shorter. The longer you make them, the lower the tuning frequency (Fb). The bigger you make them (wider) then the longer they have to be to maintain the same low Fb. Don't worry. Just get your ports and equipment and someone on here will help you with tuning, I'm sure. Link to comment Share on other sites More sharing options...
doug118 Posted July 10, 2009 Author Report Share Posted July 10, 2009 lol he could only wish it sounded like that. his windshield barely moves and there is minimal movement from his hatch holy shit this is what I've been looking for. a loud 2 door honda civic name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>"> name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>" type="application/x-shockwave-flash" width="425" height="350"> 2001 Tahoe. Huge front stage and 55+ substage http://www.stevemeadedesigns.com/board/topic/196418-another-tahoe-build-huge-front-stage-and-155-substage/ Link to comment Share on other sites More sharing options...
Ben Building Posted July 10, 2009 Report Share Posted July 10, 2009 lol he could only wish it sounded like that. his windshield barely moves and there is minimal movement from his hatchIf you get 1 15, then yours could be even louder than that. You would have more sub in a smaller car. http://www.stevemeadedesigns.com/board/public/style_emoticons/default/hairtrick.gif FYI, that DAT amp should be on your short list. Link to comment Share on other sites More sharing options...
doug118 Posted July 10, 2009 Author Report Share Posted July 10, 2009 Use the aero ports instead of a slot port for added port efficiency. You tune ports by making them longer or shorter. The longer you make them, the lower the tuning frequency (Fb). The bigger you make them (wider) then the longer they have to be to maintain the same low Fb. Don't worry. Just get your ports and equipment and someone on here will help you with tuning, I'm sure. I'm not worried about tuning, just how to place the ports, since I read often to keep aero ports as far away from the sub as possible. so should I use a 90 degree bend and put the entrance of the port near the back of the box? If you get 1 15, then yours could be even louder than that. You would have more sub in a smaller car. http://www.stevemeadedesigns.com/board/public/style_emoticons/default/hairtrick.gif FYI, that DAT amp should be on your short list. yeah if I use a single sub like planned it will be the amp I get. if I use 2 subs the t4k is on the top of the list. I'm just looking to push 2000-2500 per sub 2001 Tahoe. Huge front stage and 55+ substage http://www.stevemeadedesigns.com/board/topic/196418-another-tahoe-build-huge-front-stage-and-155-substage/ Link to comment Share on other sites More sharing options...
Ben Building Posted July 10, 2009 Report Share Posted July 10, 2009 I'm not worried about tuning, just how to place the ports, since I read often to keep aero ports as far away from the sub as possible. so should I use a 90 degree bend and put the entrance of the port near the back of the box? yeah if I use a single sub like planned it will be the amp I get. if I use 2 subs the t4k is on the top of the list. I'm just looking to push 2000-2500 per sub No bends in those ports at all if you can help it. Bends just add friction to the port, which reduces its efficiency. Sometimes, its unavoidable, but you don't want to do it if you don't have to. Link to comment Share on other sites More sharing options...
