Weightlifting/ Workout
I haven't worked my way up to running yet lol. But does or did anyone else ever have this problem... After I do an hour on the treadmill whether I wait 30mins or an hour+ after if I eat after I end up throwing it backup like a half hour after eating, but if I eat before working out I'm fine and don't throw up. I know its normal to throw up after a work out but why only when I eat after? Should I wait longer or just continue to eat before?
2008 Dodge Ram 2500 6.7l Cummins
4 FT1s
C1600.2
8 PWX 8s
ONX2.100
Audio Technix Wiring & Sound Deadener
My Youtube
Feedback
I can eat a full meal before and be fine, but if I tried to eat it after instead of before it will come back up, protein shakes also. But if I eat something small like an apple after I'm fine... just if its a full meal.
4 FT1s
C1600.2
8 PWX 8s
ONX2.100
My Youtube
Feedback
when you do run/jog start slow and finish slower until you build up obviously. try to focus on form. Get that foot under the body when you run, if you strike to far in front you cause unnecesery knee/joint pain and when you land with your foot under your body your whole body will take the blow. Also watch how your foot strikes the ground. Heel striking is bad but with
80% of todays shoes it promotes heel striking with such a thick sole. Try to land mid foot and to practice run with no shoes on. Running is so much easier when you are efficient.
I'm 275, no way i'm running bare foot. Form felt pretty good for being out of it for so long. Going again tomorrow, hope to see a little improvement each session.
SMD Super Seller
My Feedback Thread
I want to share one of my favorite burger recipes. The patties are healthy and pretty much a meal in themselves. Eat alone with a salad if trying to lose weight, or serve on a whole grain bun with a side of HOMEMADE potato wedges if trying to bulk up or add weight.
1lb 90/10 lean ground beef
1/2 cup finely chopped red onion
1/2 cup finely chopped spinach leaves, stems removed
1/3 cup dry oatmeal
1/4 cup shredded sharp cheddar cheese
1 egg
Pepper to taste
Mix everything together in a large bowl, use your hands, its the easiest way to integrate it all evenly. Separate the mixture into 4 equal parts, form into patties, and grill them up.
Note: You can use ground turkey, but I suggest adding a second egg because turkey tends to come out drier. If they are dry, use some ketchup or bbq sauce sparingly.
SMD Super Seller
My Feedback Thread
Weightlifting and dieting has become and obsession for me I've lost 90lbs so far only have 10lbs to go... january 1st, 2011 I started at 6'4 320lbs and right now I'm 230lbs. Bench press went up 150lbs during the weight loss...
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
