Well i got my new In-dash installed today and within 5 minutes of using it all of my cars interior lights when out (dashboard, lights when you open the door and even the beeping noise when you open the door went out) Also when my cars turned off i cant lock the doors anymore the key has to be in the ignition and turned for it to lock the doors... any help?
Sounds like you blew some fuses. Have you checked your fuse panel yet.
edit: exposport beat me to it...
Edited by Basshead08
System tear out has begun...Out with the old
i have a iq of 128 i graduated at the top of my class tell me how im reatrded you are the 1 thats dumb as hell you can't even spell
Look at the underlined text hahahahahahahaha
I think of it as the virgin losing the virginity technique
not just jumping in to it, and pounding away, but going at it slowly over time, to get to that full extreme
i'ed help but i unno at the moment, n im feeling kinda ill, but to the other smd'ers they will possably want to kno the year, make, n prolly model of said car, and headunit
hope everything works out fine, but im thinkin some wires got crossed someweres, did u tap into factory wires or get plug in harness?
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
oh ya, check both fuse boxs also, some things are fused under hood, n some inside car
check your ground and looks for shorts anywhere.
this happened to my friends camery after we installed a new deck. it kept blowing fuses because the ground wasnt done well enough, and he had one wire connected up wrong.
8 DC Level 4 M2 15s2 DC Audio 5ks26^2 clamshell tuned to 30hz9 Kinetik 1400sMechman externally reg'd 340 S seriesin a 99 Jeep Cherokee :DClick to see J00bles' Youtube Channel
when they connected the ground wire the indash wouldnt work so they had to connect the battery,ignition and ground to the battery so it could work
Edited by Rodrigom210
They didn't have to ground to the batt. Could've just grounded to the firewall or frame or wherever
  • Who's Online   0 Members, 0 Anonymous, 1111 Guests (See full list)
