help decide between 2 enclousures
doug118
decisions. what do you guys think
design #1
or design #2
how big of a difference would these 2 be decibel wise? like a direct swap from 1 to the other? and which one do you think would sound better for music?
edit: almost forgot, thanks footlongsam for the 2 designs
plans for setup are as follows
2 12" dc level 4xl's
1 3000-4000 watt amp. whichever I can get when ready to purchase, either sundown 3000, rf t4000.1, or american bass vfl 400.1
3 batteries
200amp alt
this is all going into a 2dr honda civic, subs and port forward sealed off from the trunk
facing forward..if you have the port to the driver side it would do slightly better at the dbdrags with the port at the opposite side as the mic. with the port on the pass. side it would be louder at the drivers seat. port in the middle would be a compromise of the other locations. depends if you want to get that last db at the drags.
good looking designs. tuff call. I think that design 1 the subs would load better and creat more pressure, but design 2 the subs would be better matched and less cancelation. but I could be wrong. I depends on what you want.. loud or good sound
////Alpine, Eclipse, Load Boss, Pheonix Gold, MB Quart,Digital Desings, Memphis, Stinger, Periphial, MTX, Visualogic
i say designs two
one- i like the cosmetic look of it
two- i think the bracing will be stronger in the smaller area chambers
Current Setup:
Factory HU with LOC
mids/highs-Insignia components
Sub- E8 in bass tube
Amp- sae-1200d
Show Setup:
HU-Sony MEX-1HD (brings massive respect for sony)
fronts - Infinity Kappa perfect comps
rears- Infinity Kappa coax
mid/high amp - Autotek 5600
Subs - 2 RE SE 15's
Sub Amps - 2xSAE-1200D
Box - 5cubes sealed
Wire- Lots of Knu 1/0
SECOND SKIN
I was leaning more towards number 2 so that helped that most said #2. depending on how much I can score some mdf for and how well the box gets built, I may build #1 shortly after and see which one sounds better to the ear. sound is top priority, I'm sure the numbers will be decent either way
  • Who's Online   0 Members, 0 Anonymous, 2673 Guests (See full list)
