18" Btl Amp Help.
shooter69
thats alright, yeah, just wire it straight to the front batt. plus to plus, negative to negative. a lot of guys will tell you to get an isolator but i dont and havent had one for ever and ive never had probs.
DD M4
Rockford Fosgate P500-4
2 Rockford Fosagate T1675-S
XS Power D3400 Under Hood
XS Power D5100 in rear
Michael Singer 200A Alt
Yea, an isolator is only necessary if you listen to your system with the car off. And, you can run the wires to the extra batteries straight to your alternator if you want.
A couple links to some box builds:
Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI,
Mini-Bump, Hummer H2, Ford F-150
My own car builds (current setup --- under construction):
Overall Thread, Kickpods, Dash, Back Doors
Subwoofer Wall
It allows more power to flow...Basically, power goes from your alternator, to your battery, to your amp, to the ground, and back to the battery. Now, we all know running bigger wire allows more power to the amp, but without upgrading the other wires, it's an incomplete upgrade of that circuit. Upgrading it will allow power to flow more freely. All in all a good thing haha
Subwoofer Wall
Very easy.
All you need is 10-15 feet of wire and a few ring terminals.
1) Pos Alt to Pos Bat
2) Neg Bat To Ground
3) Alternator/Engine to Ground
No more voltage drops!
And to help with lights dimming, you can upgrade the wiring going to the fuse box as well...that should take care of it.
Subwoofer Wall
Very easy.
your alt/engine is grounded already by being bolted down.
the last step of the big 3 is upgrading the battery ground.
  • Who's Online   0 Members, 0 Anonymous, 1256 Guests (See full list)
