shooter69 Posted March 29, 2007 Author Report Share Posted March 29, 2007 where would the second, possibly third battery(ies) go? how would i wire them into the system? Quote (1)Fi BTL 15 (1)AQ 2200d 4.33 Cubes~33hz Big Three done XS 1200 in the back Link to comment Share on other sites More sharing options...
Slinky Posted March 29, 2007 Report Share Posted March 29, 2007 trunk. wire em in parrallel Quote DD M4 Rockford Fosgate P500-4 SoundQubed HDC415 w carbon fiber cap 2 Rockford Fosagate T1675-S XS Power D3400 Under Hood XS Power D5100 in rear Michael Singer 200A Alt Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/ Link to comment Share on other sites More sharing options...
shooter69 Posted March 29, 2007 Author Report Share Posted March 29, 2007 in parrallel....back to the battery under the hood? sorry if i'm seeming slow, bro. Quote (1)Fi BTL 15 (1)AQ 2200d 4.33 Cubes~33hz Big Three done XS 1200 in the back Link to comment Share on other sites More sharing options...
Slinky Posted March 29, 2007 Report Share Posted March 29, 2007 thats alright, yeah, just wire it straight to the front batt. plus to plus, negative to negative. a lot of guys will tell you to get an isolator but i dont and havent had one for ever and ive never had probs. Quote DD M4 Rockford Fosgate P500-4 SoundQubed HDC415 w carbon fiber cap 2 Rockford Fosagate T1675-S XS Power D3400 Under Hood XS Power D5100 in rear Michael Singer 200A Alt Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/ Link to comment Share on other sites More sharing options...
sean 371 Posted March 29, 2007 Report Share Posted March 29, 2007 Yea, an isolator is only necessary if you listen to your system with the car off. And, you can run the wires to the extra batteries straight to your alternator if you want. Quote A couple links to some box builds: Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI, Mini-Bump, Hummer H2, Ford F-150 My own car builds (current setup --- under construction): Overall Thread, Kickpods, Dash, Back Doors Subwoofer Wall Link to comment Share on other sites More sharing options...
shooter69 Posted March 29, 2007 Author Report Share Posted March 29, 2007 1/0 wire, correct? and what all will the Big 3 do for me? whats the point? Quote (1)Fi BTL 15 (1)AQ 2200d 4.33 Cubes~33hz Big Three done XS 1200 in the back Link to comment Share on other sites More sharing options...
sean 371 Posted March 29, 2007 Report Share Posted March 29, 2007 It allows more power to flow...Basically, power goes from your alternator, to your battery, to your amp, to the ground, and back to the battery. Now, we all know running bigger wire allows more power to the amp, but without upgrading the other wires, it's an incomplete upgrade of that circuit. Upgrading it will allow power to flow more freely. All in all a good thing haha Quote A couple links to some box builds: Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI, Mini-Bump, Hummer H2, Ford F-150 My own car builds (current setup --- under construction): Overall Thread, Kickpods, Dash, Back Doors Subwoofer Wall Link to comment Share on other sites More sharing options...
shooter69 Posted March 29, 2007 Author Report Share Posted March 29, 2007 haha, no doubt. sounds like a nice add-on. easy to do? Quote (1)Fi BTL 15 (1)AQ 2200d 4.33 Cubes~33hz Big Three done XS 1200 in the back Link to comment Share on other sites More sharing options...
sean 371 Posted March 29, 2007 Report Share Posted March 29, 2007 Very easy. All you need is 10-15 feet of wire and a few ring terminals. 1) Pos Alt to Pos Bat 2) Neg Bat To Ground 3) Alternator/Engine to Ground No more voltage drops! And to help with lights dimming, you can upgrade the wiring going to the fuse box as well...that should take care of it. Quote A couple links to some box builds: Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI, Mini-Bump, Hummer H2, Ford F-150 My own car builds (current setup --- under construction): Overall Thread, Kickpods, Dash, Back Doors Subwoofer Wall Link to comment Share on other sites More sharing options...
ChevyBoy Posted March 29, 2007 Report Share Posted March 29, 2007 Very easy.All you need is 10-15 feet of wire and a few ring terminals. 1) Pos Alt to Pos Bat 2) Neg Bat To Ground 3) Alternator/Engine to Ground No more voltage drops! And to help with lights dimming, you can upgrade the wiring going to the fuse box as well...that should take care of it. your alt/engine is grounded already by being bolted down. the last step of the big 3 is upgrading the battery ground. Quote Link to comment Share on other sites More sharing options...
