aight so I needed a drop-in system to hold me over for a while, and I didn't want to comprimise the room in my truck
my setup up
2 kicker CVR 10s
Phoenix Gold 800.1 class D
the Kicker CVRs are wired for a 2ohm load
The amp is 2 ohm stable
however when I crank the volume 90% or more the amp will clip
Then if I am beatin' at say about volume 80% and the notes drop to a low bass the amp will clip
Protection light doesn't come on (to my knowledge) I can see the amp when I look back
The power light turns back on, and the system will start back beating after I turn the volume all the way down for about 5-10seconds.
other symptoms: head lights and cluster dims at night
I've checked the gains on the amp, and i'm not running them balls out, I usually keep them fairly low and use the HU volume to comprimise.
do you use a bass boost knob, because that usually overrides the gain?
Club 150 (15x.x)
Youtube
Future Build:
1x 15" T3 TSNS
2x Sundown Audio SAZ3000d Parellel strapped
Whats your voltage? possible voltage drop? from insufficient electrical?
head unit - Panasonic MXE CQ-C7403U
amp - Cerwin-Vega EXL 1200D
subs - (x2) Cerwin Vega V-MAX 15.4
box - 5.8 ^3 at 32hz
spkrs- Phoenix Gold Rsd Comps
sounds like voltage drop
Current Setup:
Factory HU with LOC
mids/highs-Insignia components
Sub- E8 in bass tube
Amp- sae-1200d
Show Setup:
HU-Sony MEX-1HD (brings massive respect for sony)
fronts - Infinity Kappa perfect comps
rears- Infinity Kappa coax
mid/high amp - Autotek 5600
Subs - 2 RE SE 15's
Sub Amps - 2xSAE-1200D
Box - 5cubes sealed
Wire- Lots of Knu 1/0
SECOND SKIN
how are your grounds?
Need any thing chromed? Hit me up!!!
gamer tag: (360)
mEmEnToMoRi64
My Myspace
refs:
from here: RollinSoLow, Derrick824, Ray
from c.a.c.o. : teamsubgopoof, splvictim20, SundownAudioNY
from C.A.J. : Donpisto, spladdict19, CAJunkyard, JBLCAMRY, DasBot (robot underground)
from ca.com: alxmlr789,photocrazy8
bass boost was set as equal as possible to the gains as not to override, again not set to balls out, this was one of the first things I checked.....but I will look again to make sure nothing is over looked
I haven't put a multimeter on it yet (haven't had access to one, mine broke) but according the cluster when the bass hits....i'm not getting a drop on the voltometer guage (amp might be a different story) This was the first thing I thought....is there any other way I could check this, if not i guess i'll go by and pick up another one......
my grounds are good, nice and big and short, these were also checked....
did you do the big 3 up front?
http://www.stevemeadedesigns.com/board/ind...showtopic=13280
what size is your power wire running to the back?
tried replacing your starting battery? and adding 1 in the back?
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
haven't done the big III.
1/0 going to the back, haven't replaced my starting battery, and haven't added a battery.....i could be wrong but i think 2 batteries might be overkill, eh?
my setup up
2 kicker CVR 10s
You shouldnt crank it that loud, most of the time the headunits signal clips at 65-80% the total volume number... so you are clipping the signal before it goes to ur amp
The lower the note, especially if its close to the tune frequency of the box, is when impedence is at its lowest, thus the most amount of power can be dished into the sub, and it doesnt sound like ur amp likes that
This is because you do not have a sufficient eletrical to support the power... you need a dry cell audio battery under the hood to replace the stock bat.... a dry cell or deep cycle has more reserve power for long bass notes, a starter battery has alot of current but not for as long as a deep cycle... secondly you would need a higher output alternator to recharge the batteries before they get drained by another bass note.... so a more powerful amp will only make the problem worse... third you might even need a second battery in the back...
you need to check ur voltage drop with a dmm, likely u are below 10volts...
im surprised ur subs sound fine clipping like this, u should be able to hear how bad they sound if they amp is doing this
and u are possitive the subs are wired to 2ohms?
The headunit is not for compromising... reset gains using 70-75% the total volume u can turn it up.... no bass boost at all in anyway either amp or headunit, flat eq for the low end... subsonic at 30hz, low pass at 80hz, 0 phase....
what headunit are you using?
i had this same problem where my shit would turn off until i turned the volume down ... my problems were a loose power wire and a loose ground smh ... the guy i went to to help me install the wires for my 4 channel somehow blew my fuse and used a wire twist thing to connect the two power wire pieces together ... shit melted and my wire was pretty fucked .... and as far as my ground ... i guess the bass just shook it loose.
My 02 Accord Wall Build
2 Sundown Audio Nightshade V1 18s --- 1 SAZ 3500
Sundown Audio 100.4 --- 4 Sundown Audio Neo-Pro 8s
Sundown Audio 125.2 --- 2 Morel MD-12 Tweeters , 2 Selenium ST-200 Tweeters
DC Power 270xp --- 4 XS Power D1200s | 1 D5100R
  • Who's Online   0 Members, 0 Anonymous, 1196 Guests (See full list)
