Well i was just bassing yesterday and i dropped my friend off like 5 minutes later i noticed that both my woofers werent hitting as hard anymore i checked the cables to the amp and there not loose or anything so what could of caused this?
2 15' kicker cvr
1 Kicker zx300.1
humm need more info, get a volt meter and test the pos, neg, and remote turn on termainals, then check fusing, then probe the outputs with the dmm and measure ac voltage. It could be many things, so try that and see where it gets you
Orion 2500D, Jbl Gto 75.4
Team Wolfpack Audio FSQ 15" d2, mb quart xover, tweets peerless 6.5 mids
Alpine cda-105
optima up front Knu klm 1/0
Did you check the cables inside the box, impedence of the speakers, gains, fuse?
2 - Audiopipe AP30001Ds
1 - Lanzar Opti Scion 600.4
4 - Lanzar Optidrive 1232D's
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar Opti 6C midbass
1 - Alphasonic PCT6551
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
1 - AudioControl Epic160
i had that happen once and it was because my box slipped in my trunk but i doubt thats it.
im not sure about that amp tho zx300.1 is 300w rms @ 2 ohms. those subs need 500w rms a piece. so depending on how long uve had them on that amp and how hard u push them u may have burnt up a coil. mine cut out on me once when i was pushing them too hard with my xta600.2
just sayin
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
why the hell does everybody around here way underpower their kickers?
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
i found out what it was the speaker wire wasnt touching
Well there's your problem!! those should definitely be touching.
Glad i could help :D
  • Who's Online   0 Members, 0 Anonymous, 1111 Guests (See full list)
