quick question about fuse
thank for the help sq monty but i dont think we are on the same page about the wire size
here is what i found sticky Maximum Fuse Size
00 awg 400 amps <-------------this is the wire i have
0 awg 325 amps
1 awg 250 amps
2 awg 200 amps <--------------not this one
4 awg 125 amps
6 awg 80 amps
8 awg 50 amps
10 awg 30 amps
12 awg 20 amps
14 awg 15 amps
16 awg 7.5 amps
These are the recommended maximum fuse ratings for the corresponding wire size
this is were i got the 400amp fuse from but the biggest i can find is 300amp
i hope this make sense i know my spelling suck and makes it hard to explain my self
thanks for your help
jeromy
new system in the works
(3) DC lvl 4xls 15's (one of three are here)
(2) DD z1 (done)
old kenwood four ch
4 runs of 2/0 (done)
? 200 amp alt may two ??
0 awg 325 amps
1 awg 250 amps
4 awg 125 amps
6 awg 80 amps
8 awg 50 amps
10 awg 30 amps
12 awg 20 amps
14 awg 15 amps
16 awg 7.5 amps
we're not on the same page because you weren't correctly stating what wire size you had. 2/0 is 2ga. But I see how/why you did that, noob mistake, no worries. So you're right, 400a fuse
Alpine CDA-117...Memphis 16-X03
CDT Audio SQA-4100...SEAS Prestige H1396...Crescendo MP-6
Soundstream Rubicon 1.2500d...Digital Designs 3512f
ok that is what i was thinking was going on thank again for the help have you used those resetable circuit breaker?
if so are they any good or do they wear out over time
(2) DD z1 (done)
old kenwood four ch
I'd imagine they could wear out over time but to be honest with you bro, I think i've had to replace the main power lead fuse only once in any vehicle i've ever owned since I started putting systems in 17yrs ago. And even then, the fuse didn't blow, but it was warped somehow. So I wouldn't worry too much about the circuit breaker wearing out. If your breaker trips so much to where it wears out, I highly suggest you don't do anymore installs.
2/0 is not 2 gauge. 2/0 is double-zero gauge, it's usually around 63mm^2 to 70mm^2 compared to 50mm^2 for 0 gauge.
I would use a 300A fuse personally. A 300A ANL fuse takes about 600A to pop in less than 5 seconds and there's no way you'll be generating more than that without a fault somewhere.
10.x volts fo' life!
i thought so that what we call it at work but we got it worked out thanks for all the help guys
(2) DD z1 (done)
old kenwood four ch
Do not use the resetting circuit breakers.
I have seen more then a few lately get stuck close with a fault. Seams that even ones in clean dry locations can get gunked up with shit and it keeps them from tripping.
Use a proper size fuse. You will never have to replace it if everything is installed correctly.
  • Who's Online   0 Members, 0 Anonymous, 1384 Guests (See full list)
