the red and Black 2/0 wire is extremly cheap.
2/0 Welding Cable Red Details
-$2.21 1/FT
-$2.05/FT [save 8%] Order 25+ FT
-$1.87/FT [save 18%] Order 50+ FT
2/0 Welding Cable Black Details
-$2.09 1/FT
-$1.93/FT [save 8%] Order 25+ FT
-$1.77/FT [save 18%] Order 50+ FT
www.weldingsupply.com > clamps wires > scroll down
I have ordered from there before. there real Gauge sizes
Edited by Kian
Club 150 (15x.x)
Youtube
Future Build:
1x 15" T3 TSNS
2x Sundown Audio SAZ3000d Parellel strapped
Its not bad
Heres some 1/0 gauge from them
Club 150 (15x.x)
Youtube
Future Build:
1x 15" T3 TSNS
thats not bad but i wonder how many strands it contains...
correct me if im wrong but strand count is only for flexibility right? if its bigger than say kicker hyperflex 1/0 wouldn't it be able to carry more current?
i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
Yes, this does help with flexibility. But the way wiring works is like this...
Electrons flow along those strands. With more strands, the more electrons will be able to flow from one end to the other. Thats why wire that is the same size and material with a low strand count doesnt perform well as the same size wire and material with a high strand count.
Looks like some pretty decent wire with a decent strand count.
Team MaxRetribution
Si Vis Pacem Parabellum
Isnt that only true for ac current? once you get to dc current it just flows through the copper or whatever the wire is.
I've used 4/0 and 2/0 welding wire alot, it is not flexible like what you are used to. It works great as long as you don't have any tight bends, I ran the 4/0 down my frame to the rear battery bank but i wouldn't try to run it thru the firewall and under the carpet.
2003 Ford F-150 Reg Cab layin body on 26's
2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine.
2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's
2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
thats what i thougt. higher strand count makes it easier and more current to run.
Team Bass-Hz
