DC Sound Lab
The new motor will be larger diameter then the lv5. I have told Rusty before he should have just machined a few of the lv5 motors out to work with a 4" coil and see what they could do. That lv5 is a good SPL platform, and i bet she would have been much loud with a 4" coil, but this new lv6 is going blow it away!!! But you already know this TJ. ;)
1 problem with a 4" motor-
Usually a 4" coils is about twice the weight of a 3" coil, jump up to a 8 layer coil, and your going more towards 3 times the weight of the 3" coil- added mass to a moving system kills SPL
Reason why most record breaking subwoofers are 3" coils, is because they are more efficient with power than a 4" coil
Just an example, pound for pound, watt for watt, a 4" coil cant touch a 3" coil of similar aspects, unless you have a motor design that will squeeze about 2-3 times the motor force of a 3" coil
if you have a 3" coil sub with a 50lb motor doing a 150db with 4000rms
a 4" coil sub will need a much bigger magnet assembly- or a lot more power- to get that 4" coil to the same spl as the 3" motor
So your looking at something like the very common, and popular TRF motor, which is about what, 85+ lbs? but they use just a light 4 layer coil, with a tight gap- better Bl
4" coils are great for handling more power, and thats awesome, but more power over all is needed to get a 4" coil as loud as a 3" coil
That isnt just from my mouth, its proven, tested, and well known
  • Who's Online   0 Members, 0 Anonymous, 1295 Guests (See full list)
