michaelholey Posted July 18, 2009 Report Posted July 18, 2009 I have a dual 4 ohm sub and a mono amp. The mono amp actually has 2 pos 2 neg terminals. the company says its for running parralel, etc.. I was wondering if i have my jumpers on my sub into parallel how would i wire it to the amp? thanks
Boon Posted July 19, 2009 Report Posted July 19, 2009 Just use 1 terminal for positive and one for negative. They're linked inside the amp anyway. 10.x volts fo' life!
michaelholey Posted July 19, 2009 Author Report Posted July 19, 2009 Just use 1 terminal for positive and one for negative. They're linked inside the amp anyway. so then would I put the pos on one set and neg on the other then?
alman101 Posted July 20, 2009 Report Posted July 20, 2009 so then would I put the pos on one set and neg on the other then? I hope your amp supports bridging or your gonna blow your amp bud
sphinxbccp Posted July 20, 2009 Report Posted July 20, 2009 I hope your amp supports bridging or your gonna blow your amp bud how exactly do you bridge a mono block amp? Build log: Click Feedback: http://www.stevemead...xbccp-feedback/ 03 Chevy Blazer - IPad Air 2 - ALPINE Head Unit - 4 DC XL 18s - 2 DC 3.5k - ALPINE TYPE R 5.25 COMP - 3 ALPINE TYPE R 6.5 COMPs - DC 175.4 - DC HO Alt - D3400 - 4 XP3000s - KNU 0ga - 60 SqFt Damp Pro Lots more...
Boon Posted July 20, 2009 Report Posted July 20, 2009 I hope your amp supports bridging or your gonna blow your amp bud :01nocomment8so: You're right. I bet a lot of monoblock owners blow their amps up this way. :01nocomment8so: :01nocomment8so: :01nocomment8so: 10.x volts fo' life!
DownSouthCustom Posted July 20, 2009 Report Posted July 20, 2009 how exactly do you bridge a mono block amp? X2. WTF
alvitae Posted July 20, 2009 Report Posted July 20, 2009 The reason you have 2 sets of terminals is so you don't have to try and cram a lot of speaker wires in one set of holes. it doesn't matter what one you stick your wires in. As long as you get the negative/positives right.
