On a stock 105 amp alternator, will the Kinetik HC800 (front) and the Kinetik HC2400(Rear) be enough to power a btl on the sundown saz2000 without having to replace the alternator?
Also, if anyone has an idea of the voltage i would get, people have been saying 13.8, but that was a guess by a dude on ***.
Edited by obcaraudio
Black 1998 Nissan Maxima
1st Setup: 145.8 DB Outlaw @37 HZ On Music Out Of Trunk
2nd Setup: 147.8 DB @42 HZ On Music Out The Trunk
Current Trunk Build:
153.8 DB Outlaw @ 49 HZ Out the trunk (150.8 DB Sealed)
Team gg.
it can be done without an alt but i wouldnt recommend it but if u add another battery or two u will be fine
I know a lil about everything so dont call me Mr. Know it All.
so would i get upper 13s lower 14s in voltage?
Team gg.
Your voltage should be 14.2 to 14.4 if the batteries are charged and the alternator is working.
You should get a MLA module or find a how to thread on upgrading your voltage output of the alternator to around 15 to 15.3 if you don't want to get a HO alt.
Also what type of vehicle?
2003 Ford F-150 Reg Cab layin body on 26's
2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine.
2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's
2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
I am doing pretty much the same thing, 12" BTL on an SSL 4000.1 though, and I have been told that just the two batteries would be fine.
SUCCESS is a decision, NOT a dream. You have to name the price you are willing to pay to get it.
"You didn't have an ice pick on you? Amateur. " -- Wax from Fchat.
It would be a maxima.....but if the alt is close to the batt, ill prolly consider doing the big 3
Team gg.
Guest KyleCannon
Lots of variables... if the amp is clipping... low voltage if it's all clean you can get higher voltage... a lot of variables and a lot of tweaking.... but if you're getting a good stereo why not have the power to back it? :)
Spend the money on an alt and get a hc2000 instead. saves you close to 200 at least.
Heck I bet Rob at DC Power Inc. would hook you up nicely :D
10501650_10203332501847103_1859383749711
Blown
Guest KyleCannon
Definitely... on my dc power alt i only have one battery and im pushing 2 T1500-1bds and a T600-4 no problem on a single XS Power D2400
  • Who's Online   0 Members, 0 Anonymous, 3517 Guests (See full list)
