question, wouldn't the board in open air cool be cooler than being in a metal case? I know some have fans and whatnot but I would imagine something in open air being able to cool off faster then being enclosed
the mosfets need something to cool off, which is what the aluminum casing of the amps is for. draws the heat away from the internal components to the open air.
the MEHSA, where is that located? i know its the protection system that Fosgate uses to prevent their amps from getting damaged. on the back of each of the black PCB board's is aluminum. so why would i need an insulator?
I'm pretty sure the MEHSA is conductive, which is why you need the insulator.
It's the black board thing that the transistors are attached to.
Take your multimeter and check the resistance between the legs of the FETs and the aluminium on the back of the MEHSA. If ANY of them are 0 ohms you need to have insulation between the MEHSA and the heatsink otherwise if the heatsink ever makes contact with the wrong thing your amp will blow up.
10.x volts fo' life!
are the FET's the bigger ones or the smaller ones. stupid question to ask since i know i should know this.
the only thing on the board that gets hot is the board with the 4 smaller FET's/transistors...if that matters at all.
what would i use to insulate the MEHSA from the heatsink? thermal compound?
Have you actually run it with a load on it? I dare say that'll heat up the outputs. I run amps on my bench all the time out of their cases but never with a load of anything more than an o-scope's probes.
For insulation, you need either a mica insulator or one of those rubbery thermal pad things. You can also use Kapton tape.
no becasuse the fets have no direct dissipation
yea i had a 2 ohm load on it (stable down to 2) and even if the amp was idle, the output section was warm to the touch, and heated up a bit when i played it for about 30 seconds or so, but it wasnt burning me. fibtlforlife told me that he'd play this amp full out and it would go into thermal protect after a short while, but it would cool off and he'd play it some more.
i just checked the resistance between the legs of the FET's and the aluminum backing, and they're all reading 0 ohms...but im using a veeeryyyy shitty meter so i dunno if that means anything. the leads touched together was 1.5 ohms
