I had no complaints with audiobahn, for a first system anyway. Definately checkin out what kind of RF deals I can get. Waitin for him to call so I can go check out his truck and see what he wants to do with an enclosure. Thanks for the suggestions I didnt know about that site so ill check it out. Ill show him the cvrs. Was wantin to run w.e amp at 4 ohms if possible.
tech, Ill bring it up to him but I dont know if he will want somethin used. Ill let you guys know what he decides.
Old Setup
03 DurangoRF Power T1 6.5 CompsMids/Highs Amp: AQ4x90Sub Amp: AQ 3500.1DSubs: 2 DC XL 18sBox: 12ft^3 tuned to 33HzMechman 270 Amp AltXS 6500XS 3100 x2
Highest Score to date: 151.2 db @ Headrest
Why 4 ohms?
System tear out has begun...Out with the old
i have a iq of 128 i graduated at the top of my class tell me how im reatrded you are the 1 thats dumb as hell you can't even spell
Look at the underlined text hahahahahahahaha
I think of it as the virgin losing the virginity technique
not just jumping in to it, and pounding away, but going at it slowly over time, to get to that full extreme
Room for sub upgrades if he gets the bass bug and wants better subs. Could potentially save him an amp. Chances are ill jus get a mono d amp and run it at 1-2 ohms but if i could find a 200wx2 @ 4 ohm for 150 or less and I know the amp is credible would just make things easier. It's not like it has to be 4 ohms.
Old Setup
So we put 2x12s in his truck to see if they would fit and it looks like they should no problem. So now he wants 2x 12s to run at around 300-400w rms. I can see he will get addicted to it quickly but doesnt have the money to upgrade much. His lights were dimming like crazy on a little 400w rms audiobahn amp. Most likely gonna drop the rms to 300 until he can do big3 and upgrade electrical.
Another question. His battery terminals has side terminal with bolt that dont allow anything to really be attached. Whats the best way to fix this without changing much. If there is a way. Never had to deal with a battery with side terminals
Old Setup
is ur ground and all your connections good? I cant believe a little 400w RMS amp would strain an electrical system like that. Im only runnin 1k and i dont get drops unless im at idle.
If anything it'd be the power but the thing was it would dim the lights but the volt meter wouldnt drop below 12.
A little off topic but was wondering a kind of guesstimate on what the db's of 2x 12s @ 400w rms would be. I know there's alot of factors, but say in a correctly built ported box for the subs. Would it even break 100dbs? Lol. Just kind of thought of it. Maybe it a stupid question but am curious since it most likely won't ever get metered.
Old Setup
