Seems people have ALOT of problems putting caps on their re-cones so this is how it is done :
Buy two of these containers of Loctite FIVE MINUTE epoxy w/ mixing tubes at Lowes (DO NOT USE ONE MINUTE):
First Step :
http://www.sundownaudio.com/misc/how-to/Ni...ap/CIMG2514.MOV
Put epoxy around the edges of the disc as shown - make sure to get a good bit in the little holes so it is filled in.
Second Step:
Wait about 5 minutes for the first step to dry.
http://www.sundownaudio.com/misc/how-to/Ni...ap/CIMG2515.MOV
CAREFULLY make a bead around the dust cap to fill in the gap area. You will see Brandon traces back a bit at the end - this is because the epoxy keeps dripping out a bit and we don't want it on the cone. Don't put too much or it will run over onto the cap!
- Jacob Fuller
- Owner, Sundown Audio
- Sundown Audio on FACEBOOK
- Please DO NOT PM ME -- use my email address -- [email protected]
Jake, I should have taught this tutorial since I've put on a dust cap almost as much as you guys :)
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
if by chance you do get some on the cap dont panic wait till it starts to get kind of solid like jelly and use your finger and it should peel right off
VEHICLE:1993 Ford F-150
ELECTRICAL:1-350Amp 1-200Amp Idle Excessive Amperage Alts.
BATT'S:13 Stinger SPV70's
HEAD UNIT:Pioneer N1
MIDBASS:2 10" 2 8" Sundown prosound protos
SUBS:3 NSv.2 18s in a series tuned 6th order
SUB AMPS:3 Sundown SAZ-4500D
MIDBASS/TWEETER AMP:Sundown SAX-200.4 Simon Eichenberger is the King
Indeed - CA can work quite well in many cases - but I have found it doesn't hold very well when sticking the poly cap to the poly stiffening disc, though. Also - the epoxy looks very smooth and nice around the cap where CA glue tends to get rough and bubbly around there :)
- Jacob Fuller
  • Who's Online   0 Members, 0 Anonymous, 642 Guests (See full list)
