Second Skin needs help naming a new thermal insulation product.
1. Second Skin Heat Destroyer
2. Second Skin Thermal Control
3. Second Skin Temperature Control
4. Second Skin Heat Limiter
* Head Unit: Kenwood KDC-MP732
* iPod Interface: KCA-iP500
* Front Stage: Rockford Fosgate Power T1652-S
* Front Stage Amp: Rockford Fosgate Punch P400-2
* Rear Stage: Alpine SPR-13C Type-R 5-1/4"
* Amp: Rockford T10001bd
* Subs: (2) 15" Rockford P3s
* Front Battery: Optima RedTop
* Back Battery: Kinetic Hc2400
* Wiring: Rockford 1/0
* Big 3: Rockford 1/0
* Enclosure: Idyllic
Second Skin Triton
Second Skin North Pole
Second Skin Kelvin (http://en.wikipedia.org/wiki/Kelvin)
Second Skin Shivering
Second Skin solidification
Second Skin Exothermicity
Second Skin Flash Freeze
Second Skin Supercooling
Just a few Ideas lol.
2008 Dodge Ram 2500 6.7l Cummins
4 FT1s
C1600.2
8 PWX 8s
ONX2.100
Audio Technix Wiring & Sound Deadener
My Youtube
Feedback
As usual, Second Skin is doing its best to bring new and exciting products to the market.
This one is certainly no exception.
Over the years we have a had a lot of street rod and race car customer come to us looking for a product that could withstand the high temperatures on the engine side of the firewall. Some cars reach levels of 1000 degrees f. and for this application, we had no product to offer them.
Now we are about 8 weeks out from releasing our newest thermal insulation mat.
This new material is a multi layer composite that can withstand temperatures in excess of 1000 degrees when as little as 2 inches of air space is provided between the heat source and the product.
At ¼ inch thick and weighing in at .25 lbs per sq foot this is going to be our best thermal insulation material yet.
The foil is about 12 mils thick with a dimpled texture to increase surface area.
The Organic fibers are capable of withstanding temperatures over 1000 degrees, and the pressure sensitive adhesive is an acrylic hybrid that will grip on to any painted or primed metal surface, as well as plastic.
When subjected to a heat source of 1200 degrees the opposite side of the panel will get reduced to around 350 f.
When subjected to a heat source in the 300 degree range, the opposite side of the panel will get reduced to around 85 f. or so.
Not only can it be used on the engine side of the firewall, but it can also be used under the car, above the exhaust or transmission to block external heat as well.
Now, all we have to do is come up with a name for it.
That is where you come in. We are offering a $250 gift code to the first person that suggests the name that we decided to use.
We are posting this offer on several different forums and will be selecting a winner in the next month or so.
We have about 8 weeks before the product is ready to ship so we can take our time and wait for the right name to show up.
Thanks for your help!
ANT
www.secondskinaudio.com
Second Skin's perfect skin
thermal hybrid skin
Second Skin's heat reducer
external heat skin
thermal skin
Organic thermal skin
Engine Wrap
Heat Retreat
^ Add Second Skin infront if necessary.
Old Setup
03 DurangoRF Power T1 6.5 CompsMids/Highs Amp: AQ4x90Sub Amp: AQ 3500.1DSubs: 2 DC XL 18sBox: 12ft^3 tuned to 33HzMechman 270 Amp AltXS 6500XS 3100 x2
Highest Score to date: 151.2 db @ Headrest
  • Who's Online   1 Member, 0 Anonymous, 1119 Guests (See full list)
