I want some of the big groundpounders advice....if you havent had to fix your roof please don't comment because I'm not trying to waste my time/money doing things that don't work.
So does anyone have an good idea on how fix your roof....I broke two of my roof braces in my blazer and I'm thinking of using Great Stuff foam to keep the braces from slapping....I was wondering would if adhering mdf panels to my roof would make it flex less.....but at the same time I don't want it to continue to flex and make them fall off....
and YES I have my roof deadened with 3 layers it's just not helping much.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
Anyone have suggestions....I'm going to be tearing the headliner out tomorrow to start "working" on it and can use some advice as I haven't ever had this problems before.
My YouTube Videos
Nobody has had this problem?
My YouTube Videos
I broke one of my braces right near the sunroof.
I sanded the area as best I could, then I used a cold weld metal epoxy all between the roof and the brace, then I wrapped deadener over the brace and onto the roof skin.
I havent had a problem since.
In other cars I have screwed and glued MDF to the braces and sprayed great stuff up under the MDF and that worked out well too.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
Good info....yeh its the one right behind my sunroof and then the one all the way to the rear of the truck where the subs load onto the roof.
My YouTube Videos
I had those problems at 140db. Now the roof it self is good at 147+. I added 3/4 mdf glued to the roof and screwed to beams, then spray foamed every hole, then put the sound deadner over the mdf and roof bows.....
Go to my build log and you will see, worked really good.....
2007 Great Wall So Cool
4-12' RE audio MX's
Stetsom 7k2D
6-Batts
3-Mechman 250 amp Rhino's
I have never had to fix my roof but I work in a bodyshop!Automotive paint stores have this 2-part adhesive called panel bond,it is used to attach door skins to the door brace after you install the doorskin.it holds up good considering how many times you shut your door.Its almost bulletproof!
2001 Southern Comfort Suburban sittin on 26"s
Eclipse 6620 double din head unit (2004 dash mod)
4-AQ 3500D amps @1 ohm
8-Cadence 6.5 midbass 4- in each door.
Image Dynamics Cd 1 pro HLCD
4-runs of KnuKoncepts 1/0 power wire
4-DC AUDIO lvl 4 xl 18"s in a wall
2-MECHMAN 270 AMP alternators(2 more on the way)xs power VCM
7-Deka intimidator group 31 batts(soon to be Xs power)
2-Rockford Fosgate Prime r300.4(1 bridged on mids, 2nd on CD1 horns and rear door speakers)
1-Rockford Fosgate 360.2(operated by Palm tungsten T5)My link
Did you fix it yet?
Actually haven't had time been working on my dad's t-line bandpass.
My YouTube Videos
