marquettefan247 Posted July 24, 2009 Report Share Posted July 24, 2009 Alright I have just spent the past four hours trying to figure out why my amp has bad feedback. I redid my whole system checked the rcas, changed the spot of the ground. reset everything. After hooking it all back up I get a sound just like before out of my sub. When I start My car I can hear my engine noise through my sub. When I have my car off I get a heartbeat sound coming out of my sub. How do I fix this? I have had it with car audio and need help. Could it be my deck? Quote 1995 Ford Mustang 3.8l V6 5 Speed Plans: 2 12 inch dc Level 4s DC 2.0k Amp KCA 1/0 Power Amplifier Installation Kit 220 Amp Alt XS Power 12V D925 AGM Battery Stinger Volt Gauge Rockford Fosgate RCAs Box built from birch. Probably tuned to 32 Hz 0 gauge wiring for extra battery Dynamat “I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.” Al McGuire “The only mystery in life is why the kamikaze pilots wore helmets” Al McGuire remember this always Close only counts in horseshoes and hand grenades Link to comment Share on other sites More sharing options...
uluahunta808 Posted July 24, 2009 Report Share Posted July 24, 2009 are you running ur power wires next to ur rca's? and it might be ur deck but first try moving the wires. my friends car does the same thing Quote Link to comment Share on other sites More sharing options...
marquettefan247 Posted July 24, 2009 Author Report Share Posted July 24, 2009 I am running my power wires on the driver side and the rca and remote on the passenger side Quote 1995 Ford Mustang 3.8l V6 5 Speed Plans: 2 12 inch dc Level 4s DC 2.0k Amp KCA 1/0 Power Amplifier Installation Kit 220 Amp Alt XS Power 12V D925 AGM Battery Stinger Volt Gauge Rockford Fosgate RCAs Box built from birch. Probably tuned to 32 Hz 0 gauge wiring for extra battery Dynamat “I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.” Al McGuire “The only mystery in life is why the kamikaze pilots wore helmets” Al McGuire remember this always Close only counts in horseshoes and hand grenades Link to comment Share on other sites More sharing options...
J00bles Posted July 24, 2009 Report Share Posted July 24, 2009 it is most likely your deck then. if it is a pioneer, its almost certain that the noise is coming from a bad ground on the deck. Quote 8 DC Level 4 M2 15s2 DC Audio 5ks26^2 clamshell tuned to 30hz9 Kinetik 1400sMechman externally reg'd 340 S seriesin a 99 Jeep Cherokee Click to see J00bles' Youtube Channel Link to comment Share on other sites More sharing options...
marquettefan247 Posted July 24, 2009 Author Report Share Posted July 24, 2009 as you can see from my sig it is a kenwood it was like 70 bucks any suggestions on what one I should use? Quote 1995 Ford Mustang 3.8l V6 5 Speed Plans: 2 12 inch dc Level 4s DC 2.0k Amp KCA 1/0 Power Amplifier Installation Kit 220 Amp Alt XS Power 12V D925 AGM Battery Stinger Volt Gauge Rockford Fosgate RCAs Box built from birch. Probably tuned to 32 Hz 0 gauge wiring for extra battery Dynamat “I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.” Al McGuire “The only mystery in life is why the kamikaze pilots wore helmets” Al McGuire remember this always Close only counts in horseshoes and hand grenades Link to comment Share on other sites More sharing options...
Boon Posted July 24, 2009 Report Share Posted July 24, 2009 Does it do it with the RCAs disconnected? Quote 10.x volts fo' life! Link to comment Share on other sites More sharing options...
marquettefan247 Posted July 24, 2009 Author Report Share Posted July 24, 2009 nope Quote 1995 Ford Mustang 3.8l V6 5 Speed Plans: 2 12 inch dc Level 4s DC 2.0k Amp KCA 1/0 Power Amplifier Installation Kit 220 Amp Alt XS Power 12V D925 AGM Battery Stinger Volt Gauge Rockford Fosgate RCAs Box built from birch. Probably tuned to 32 Hz 0 gauge wiring for extra battery Dynamat “I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.” Al McGuire “The only mystery in life is why the kamikaze pilots wore helmets” Al McGuire remember this always Close only counts in horseshoes and hand grenades Link to comment Share on other sites More sharing options...
zfrerichs Posted July 24, 2009 Report Share Posted July 24, 2009 you could try better rcas i dont know what your running tho Quote Roseville, CA Link to comment Share on other sites More sharing options...
Dr. Johnson Posted July 24, 2009 Report Share Posted July 24, 2009 loosen the amp from the panel and lift one side up. I had a similar problem with my SAX 100.4. They make the amps with such close tolerances that the bottom touches the components and makes the noise. At least that was the problem for me. I just put washers under all four spots to lift it up and it works great now. Quote Link to comment Share on other sites More sharing options...
marquettefan247 Posted July 24, 2009 Author Report Share Posted July 24, 2009 my rcas are rockford fosgate got em at best buy and my system is in my sig Quote 1995 Ford Mustang 3.8l V6 5 Speed Plans: 2 12 inch dc Level 4s DC 2.0k Amp KCA 1/0 Power Amplifier Installation Kit 220 Amp Alt XS Power 12V D925 AGM Battery Stinger Volt Gauge Rockford Fosgate RCAs Box built from birch. Probably tuned to 32 Hz 0 gauge wiring for extra battery Dynamat “I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.” Al McGuire “The only mystery in life is why the kamikaze pilots wore helmets” Al McGuire remember this always Close only counts in horseshoes and hand grenades Link to comment Share on other sites More sharing options...
