Alright after I sell my quad I plan to update my system with running a 15" BTL powered by a RF T20001Bd amp. I would run 1/0 gauge power wire to the trunk where I would have a Stinger Power2 SP1000, I would jus run one wire from the front battery + to the back +, and just ground each. Woulld also use 1/0 gauge for the battery grounds, and most likely the "Big 3" in all 1/0 gauge. My alternator is 102A. Would this be enought to run a BTL for a daily driver and a comp every once in a while?
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
Yes it would, but I wouldn't use stinger wire if I were you. You can get better stuff for a lower price.
1- T1000.1bd's
3 Maxx 29 deep cycles
4 runs of 1/0 gauge
-Big 3
All in a CAR.
you will be fine with that electrical, but you will not have awesome voltage. your headlights will dim a lot, and id charge your batteries often.
DD M4
Rockford Fosgate P500-4
2 Rockford Fosagate T1675-S
XS Power D3400 Under Hood
XS Power D5100 in rear
Michael Singer 200A Alt
I would eventually update the alternator to a Irragi "Dominator" Series which is 200A/ 75A idle, would that hold up better? What recommendations would yall have to make it a little stronger but not zap a hole in my wallet?
2007 Chevy HHR LT
UNDER CONSTRUCTION
dude i have almost the exact same setup you do, but with kinetik hc1400 and i have HID headlights and they dont dim one bit. and i dont have a HO alt. i have a stock 100A alt in my jeep cherokee
Oh, I was also thinking about the Kinetik HC1400 and HC1800....so it works fine for you, and another question when you run second batteries do you have to charge them much?
2007 Chevy HHR LT
UNDER CONSTRUCTION
not really...your stock alternator can handle 2 batteries fine, although you may want to charge them when you pound at full tilt for quite some time. just don't pound with your engine off.
Edited by Dale
  • Who's Online   0 Members, 0 Anonymous, 821 Guests (See full list)
