Ok so I traded back the DD 9917 to my boss for the station wagon.
Well, he says, lets build a wall for this weekends Usaci comp. Even though we don't compete in Usaci anymore, there is a show close so.
Well turns out, he is going to let me run it the rest of the MECA season, since I have 15 points already, and the car stays in the same class.
Wall 12ish cubic feet, external port tuned to 34hz.
2 DD 9917's Dual 2.
2 Power acoustik 5500D's
2 Kinetik HC2000's
Finished pics and number tonight. Bout to leave for the show.
Oh ya, I built this in 3 days, solid as a rock. This is just for this weekend. After that it will be brought back and glassed on the inside, internal bracing, more 0/1, and more batteries.
Just burping it for this weekend, and maybe some "quiet" demos =]
Got port?
Me in the box. I'm 6'1 and was pretty comfortable
Since then, while I was at my normal work, the face has been mounted, deck, batteries, and all wiring has been buttoned up. Just gotta mount the subs.
wheres the rest of the pics :(
R.I.P!
(Nov-29-2009)
92 explorer
current build
X2 :D
Well, things didn't go like we wanted.
Low voltage had one of the amps cutting out half way through our run.
Tuned to low, peak was at 36hz O.O
Blew open a corner.
Things just need to be addressed. Which is expected for a 4 day build ya know?
I seem to have misplaced the car pics....
BUT does anyone want pics from the hot body contest? =]
