how can i design a box for a single cab?
ok so i scooted the seat up all the way. its 57'' inchs wide. 21'' from the floor to the top of the seat. 10'' from the back of the seat to the back of the cab(lower part). 4'' from the back of the seat to the back of the cab(higher part).
how many cubes can i get per speaker???
Check out my build log for a single cab gmc. I did 3cuft and made box pretty big but you don't have to go that big if you don't want to. I have limited leg room lmao..... Just for ideas
2 AQ 10'' HDC3 copper subs
1 3500d AQ amp
146.3db on TL with stock electrical in single cab truck at 32hz
RESULT: 1st place at comp, 3rd overall out of 20 cars
Check out my build as well. I stuffed 4 real 12's (not shallow mounts) in my standard cab S-10 in a 3.9 cube box. It was pretty easy but I had to go with 1/2" mdf which is my only regret.
Current System:
Pioneer 6900 HU
Front Stage: (for now)
Soundstream tarantula 5.25 in the doors
Soundstream tarantula 4x6 in the dash
Kenwood 400.4 for mids & highs
Bass:
4 Soundstream RW-12's
2 Power Acoustik Stax 4000/1D's
single chamber box, 2.65 cubes.
Currently under the knife being bagged
Rebuilding err'thang
sick trucks guys. will i have to get a bigger amp if i'll be running 1200-1400 rms?
A bigger amp than what? my amps claim 2200 RMS but its realistically about 1500
Current System:
Pioneer 6900 HU
Bass:
ok. that answers all my questions, but one.............will it be necessary to buy a new alt and run 0ga wire?
oh and it has dual battery setup al ready :yahoo:
necessary no, but it would be smart to AT LEAST upgrade the wire
yeah, only need a new alt when ur pushing over 1,500rms solid. i can do 1,500rms with my stock electrical. hell i got a 146 on the Tl with stock electrical. good luck with ur build and keep us posted
1 3500d AQ amp
