alright, sorry if i sound snobby, but once again, I'M NOT DESIGNING THE BOX!!!!!!! if you wish, you can design a 4 12" slot port box design for 4 12" HFI12D4 subwoofers. i am not doing the round port. idc if that's what they tell me to do. so if you want to design me a box for 4 12's that is slot port, please do and i will use that. :aggressive:
K. If only because it stops you trying to make a stupid iso-bandpass box.
Maximum dimensions, vehicle, any particular requirements?
I'm going to get on the piss bigtime tonight so it'll have to be tomorrow.
10.x volts fo' life!
wow. O.O okay man. umm....3 feet wide, 3 feet tall, by 3 feet long. i can go a bit higher if need be. after all, it is a minivan.
thanks in advance man. and sorry about eariler. :give_rose::sorry:
EDIT: it's a 2001 dodge grand caravan sport. i'm taking out the third row seats. and not low tuning. maybe 33HZ?
Edited by BassAddict32
1994 Ford F150 reg cab
2 HFX 12's
Audiopipe APSM-1300
so i thought about things, and i realized that 4 dual VC 4OHM subs will get a 2OHM load. with a mono amp, i'd get less. so with a 1600W amp (BXI1606D) i'd end up getting about 1100W. so i thought, why not just run 2 amps? so does anyone think i should run 2 Crunch PZI1000.1 amps? i think it'd be better. grant it, i don't think they put out 1K watts, but that's okay because the subwoofers only handle 600W peak and i don't want to put to much. i just think that each amp to 2 subwoofers would be a good idea. any thoughts?
2 HFX 12's
Audiopipe APSM-1300
Kicker highly does not recommend useing SOLO's in an IsO-Baric set up.
I have long talks about it with Kicker as my original plan was 2 RF 1501BS 0n 4 L7s in iso-baric formation and they shot me down hard.
It can be down but the Techs sayed that it usually sound pretty bad. Hence my screen name ISO I love the concept of running iso-baric.
No you don't need 2 amps to make a push pull config you just need to know how to wire your subs.
Sorry for the bad news.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
okay, i'm not using kicker. but the 2 amps will not runng be running them iso if boon will make me a box.
2 HFX 12's
Audiopipe APSM-1300
okay, let me rephrase that and explain......
i will not be running kickers at all, so i do not have to worry about that. now, as for iso style, if boon will make me a box for my 4 12's, then i will not use iso. if he does not, then iso it will be. either way, i will be using 2 seperate amps. dual VC 4OHM X 4 = a 2OHM load. so if i use 2 amps, i can get a 1OHM load to each amp, pushing it full power. :) hopefully 400W to each.
let me see how things work out with boon before i pick iso or not. either way, i will be using 2 seperate amps.
2 HFX 12's
Audiopipe APSM-1300
get the gear first, then worry about the box after that LOL, always with the *im gonna get this and that* Buy it build it, blow shit up with it :)
either way, your moms van will be loud :P
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
lol. well i change things because i can't decide. however, the amps i'm sure with, because it'd make more sense. and i know what subs i'm getting. just the box is a issue. but i should have things going, once i sell some stuff. :) that'll be soon.
2 HFX 12's
Audiopipe APSM-1300
