tehbert0 Posted July 29, 2009 Report Posted July 29, 2009 What is the point of having an aeroport on the outside of a box. i've seen them around an jjust wondering why its done http://motorcitydesignsaudio.com
Stephen Posted July 29, 2009 Report Posted July 29, 2009 to save airspace you can cook bacon shirtless if you're not a pussy...lol not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be. DC POWER
tehbert0 Posted July 29, 2009 Author Report Posted July 29, 2009 then would calculating the size andl length of the port be the same? and just put it outside the box http://motorcitydesignsaudio.com
BJD3 Posted July 29, 2009 Report Posted July 29, 2009 then would calculating the size andl length of the port be the same? and just put it outside the box Yes, but remember, you don't have to calculate for the airspace the actual port would take up, so the lengths would differ. I'm not explaining this well. Basically, you couldn't calculate the port length needed if it was inside the box and then just decide to have external ports. Or vise versa. Anti Peel and Seal...lol You may be offended by the above. Don't take it personally, I'm just abrasive. 2002 Buick Park Avenue DC Level 4 M2 12 D2 Car Audio Bargain 1600.1 Eclipse CD3200 ~2 cubes @ 34 hz. Stinger Roadkill Expert
tehbert0 Posted July 29, 2009 Author Report Posted July 29, 2009 how would you calculate the legnth then http://motorcitydesignsaudio.com
Rogers Posted July 30, 2009 Report Posted July 30, 2009 the same way you normally would.. but dont figure in port displacement... http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774 93 Saturn SC2My system4 SA-15's Walled 2 Cerwin-Vega S2000's 3 Kinetik Hc2000's Dual 200amp alts. you guys done with the peepee touching contest or do I need to end it?
