I have 2 cerwin vega stroker 12 inch dual 2 ohm, box is aprx 4 cubic foot measured on the outside including a port that is shared. a mtx 1501d rated 1137 watts rms at 2 ohm. big 3 has been done,and a 200 amp alternator installed. the car is 2001 pontiac grand prix and the trunk has had dynomat done. my max spl is 141.1 db at 52 hz. i would like to get 150 db or higher. are there any suggestions? thanks in advance.
150dB what? Legal, sealed, termlab?
Can't be done with your equipment. You'll need at least 4kw to even get close. More like 6-8kw.
10.x volts fo' life!
The current world record in the trunk is 154db usaci outlaw.
and that was on like 5x the power of your amp, with :censored: subs, at :censored: hz. :D (Don't know if I should be giving anymore information on that setup)
816-591-6592
www.kcrimshop.com
I agree, need alot more power and subs better suited for high spl
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
termlab mic at the front passenger side windshield...legal?. these subs say they can handle 2000 watt rms 4000 max. what amp would you recommend? What frequency should i be aiming for? will a larger box help? if i have to I'll give up my entire back seat space, it has already been removed, but didn't really want a wall.
subs forward and port forward sealed off from backside of the trunk with about 3 to 4000 watts should do the trick oh with about 3 cubic ft. per sub with about 16 to 20 square inches of port per cubic ft. tuned at about 40 hertz.
TEAM GROUNDPOUNDERS INC.
156.5 OUT THE TRUNK OF A 95 CADDY
W/1 SUB & 2AMPs
score done on a termlab mic in the kick
on the dash sealed was 154
  • Who's Online   0 Members, 0 Anonymous, 1989 Guests (See full list)
