I use 2" wood screws for the box and pre drill the holes. For the sub, i use 1 1/4" wood screws.
2000 White Ford Ranger
5" RCD lift
33x12.50 Mickey Thompson MTZs on 16x8 Mickey Thompson Classic 2s
Euro Altezza tail lights
5% window tint
Clarion Indash
4 Q Power 15s
1 Sundown 2000
1 DC power 300 amp alt(on the way)-soon to be 2
2 powermaster d925s batteries
Second Skin Deadener
Highs/mids amp-Crossfire 404
Door speakers-2 5x7 mb quarts and 1 5 1/4" black max up front, stock 5x7s in the rear
Soon to Come:
Lots of SA-8s
2 Sundown saz 3500s(possible 4500s)
5-7 d3100 batteries
custom clamshell
BNC 8s for mids
undecided tweeters
I use 1 3/4 drywall screws
System tear out has begun...Out with the old
i have a iq of 128 i graduated at the top of my class tell me how im reatrded you are the 1 thats dumb as hell you can't even spell
Look at the underlined text hahahahahahahaha
I think of it as the virgin losing the virginity technique
not just jumping in to it, and pounding away, but going at it slowly over time, to get to that full extreme
i use a 18ga bradnailer for the box with liquid nail on all the inside seams and i use t30 torx head 1.5in screws for the subs
Edited by Jville140db
Car is 2010 Scion Tc
Currently in car
Deck- Sony XAV-60 in-dash mobile video system
Speakers- Rockford Punch 6.5in comps in the front and coax in the rear
Subs- 2 Gen 3 Rockford P3 12's dual 4 ohm
Amps- Rockford P1000-1bd and P400-4 Alpine Mrp-f300 is in for P400-4 which is out to service
Wiring- all rockford nuff said
Enclosure- Dual 12in custom box by SRQ
Battery- Optima Yellow top with big 3 done
Sound Damping- All Dynamat products 1-2 layers throughout with liner on top
Link to my build log- http://down4sound.co...=newpost&t=5275
Link to my youtube- http://www.youtube.c...ser/Jville140db
MECP Advanced CEA # 110531
BassBox 6 Pro for Box Building/Re audio box calculator
If you can hear the passenger it aint loud enough!!!!!!!
QUOTE (MickyMcD @ Sep 25 2009, 07:25 PM) "My system has 30 speaker terminals, that means shits wanging doggggg....."<!--QuoteEnd--></div>
what kind of sub do you have?
when i'm using any sub over 50 pounds i use 1 1/2 inch bolts with nut plates on the underside of the baffle.
on smaller subs i just use 1 1/2 inch wood screws.
How do you get the nut plates under the baffle? do you like glue them to the wood or something before you put the sub in?
Team Bass-Hz
i use these. hammer them into the wood and then put some resin around it for good luck.
http://www.boltdepot.com/t-nuts.aspx
