pervitizm Posted August 3, 2009 Report Posted August 3, 2009 I think I might have a ground issue although I'm not 100% sure on that. It started about two weeks ago on a trip down to KC. My subs were playing fine then all of a sudden I would get a loud thumping sound through the subs. Even when the boost is down to 0 (virtually no subs playing at all) I will still get the thump every now and then. My gains on both amps are not even on half and my boost on the amps are only turned a quarter of the way. I'm going to re-run the RCA's to get them as far away from the power wires a possible, but just wanted to run this by the group to see if anyone else has had this problem before. I don't want to re-run the wires just to find out that my issue is still on going. 2007 Chevy Suburban LT1 Pioneer AVH 5700 DVD Diamond Audio D3 6 1/2 components Kicker 06ZX650.4 amp Kicker 06ZX2500.1 (x 2) DC Sound Lab Level 4 18's with Level 5 coils Autotek Mean Machine 400.1D (replaced) Soon to come: rims body kit flow master pipes Confuscious say "he who say it can't be done shouldn't be bothering man busy doing it" Now feel free to go crawl back under that rock and leave this to the professionals....
kickerfanatic Posted August 4, 2009 Report Posted August 4, 2009 I think I might have a ground issue although I'm not 100% sure on that. It started about two weeks ago on a trip down to KC. My subs were playing fine then all of a sudden I would get a loud thumping sound through the subs. Even when the boost is down to 0 (virtually no subs playing at all) I will still get the thump every now and then. My gains on both amps are not even on half and my boost on the amps are only turned a quarter of the way. I'm going to re-run the RCA's to get them as far away from the power wires a possible, but just wanted to run this by the group to see if anyone else has had this problem before. I don't want to re-run the wires just to find out that my issue is still on going. sounds like something is loose and touching when ever you hit a bump. check all wires at the amp, the grounds, wires behind the radio, any eq's or crossovers is there is... but i can almost be positive its a loose wire touching something while the car shakes.. try parking the car with the radio on and car running then go thru every wire and shake them and wiggle them evem at the amp where they screw in.. something will make noise when moved.. 4 15'' kicker L7 subs ( only 2 being used right now ) 1 kicker zx2500.1 ( another soon 2 come ) box is 9.5 cubic feet slot portd thur the back seat 1 kicker zx650.4 amp powering 4 10'' ev dl10x mids ( rear deck ) 1 kicker zx350.4 power 4 8'' beyma 8mi100 mid/highs ( 1 on each door ) 2 runs of zero gauge wire ( about 60 feet total. ) big 3 done in zero gauge kicker wire 3 runs of 4 gauge for voice amps and eq' and crossover 2 kinetik hc1800 batteries in the trunk and 1 optima yellow top under the hood 260 amp irragi high output alternator ( soon to be 2 alt's ) alpine cda 9856 ipod headunit kicker kx3 3 way crossover & a old school alpine 3342 digital 11 band sound field processor eq. ( search for ( 88bonnsse ) on youtube.com to see my videos..
WaTTz305 Posted August 4, 2009 Report Posted August 4, 2009 im 100% sure its your rca's its happened to me millions of times
