Saltine Posted April 4, 2007 Report Posted April 4, 2007 im unsure of which subs to order, the dual 1 ohm or dual 2 ohms i dont know which amp i plan on running so which would be better in the end. i dont even know what 1 ohm pulls parallel and series any advice. subs are gonna be fi BL's with cooling, flatwind for daily use
sean 371 Posted April 4, 2007 Report Posted April 4, 2007 If you run the coils in series (pos on amp to pos on Coil 1, neg on Coil 1 to pos on Coil 2, neg on Coil 2 to neg on amp) then it will double the ohm load. If you run parallel, it will halve it. So if you're getting a 1 ohm stable amp and 2 subs, get dual 1 ohm subs. You'd wire each sub's coils in series, and then the subs together in parallel. A couple links to some box builds: Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI, Mini-Bump, Hummer H2, Ford F-150 My own car builds (current setup --- under construction): Overall Thread, Kickpods, Dash, Back Doors Subwoofer Wall
Slinky Posted April 4, 2007 Report Posted April 4, 2007 x2 DD M4 Rockford Fosgate P500-4 SoundQubed HDC415 w carbon fiber cap 2 Rockford Fosagate T1675-S XS Power D3400 Under Hood XS Power D5100 in rear Michael Singer 200A Alt Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
