shooter69 Posted April 4, 2007 Report Posted April 4, 2007 Ok, i've got the subs and amps picked out....2 12" Fi bl's (p-chamfer, cooling...not sure about the flatwind), and two NINe.1's. the box....not too sure. but let me know if this would sound worth a damn. any other suggestions or changes are welcome. http://www.subwoofertools.com/forum/ported...;Fs=27&CE=0 (1)Fi BTL 15 (1)AQ 2200d 4.33 Cubes~33hz Big Three done XS 1200 in the back
Eddy722 Posted April 4, 2007 Report Posted April 4, 2007 The P Chamfer is included if you select the Cooling Option. Just so you know.
Slinky Posted April 4, 2007 Report Posted April 4, 2007 i think it would sound worth a damn. good choices. DD M4 Rockford Fosgate P500-4 SoundQubed HDC415 w carbon fiber cap 2 Rockford Fosagate T1675-S XS Power D3400 Under Hood XS Power D5100 in rear Michael Singer 200A Alt Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
shooter69 Posted April 4, 2007 Author Report Posted April 4, 2007 ed--thanks. so they would just be pulling an extra 10 bucks away from me for nothing then? slinky--alright, thank you....should i fourty-five the corners of where the yellow and black connect, green and black connect, and where teal and violet connect? (1)Fi BTL 15 (1)AQ 2200d 4.33 Cubes~33hz Big Three done XS 1200 in the back
sean 371 Posted April 4, 2007 Report Posted April 4, 2007 If you want the best overall sound, 45 alll the corners. I plan on doing that as soon as I get some more resin. A couple links to some box builds: Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI, Mini-Bump, Hummer H2, Ford F-150 My own car builds (current setup --- under construction): Overall Thread, Kickpods, Dash, Back Doors Subwoofer Wall
shooter69 Posted April 4, 2007 Author Report Posted April 4, 2007 should i just 45 them with nothing but resin? or fourty-five with wood and then add some resin? (1)Fi BTL 15 (1)AQ 2200d 4.33 Cubes~33hz Big Three done XS 1200 in the back
shooter69 Posted April 4, 2007 Author Report Posted April 4, 2007 anyone???? (1)Fi BTL 15 (1)AQ 2200d 4.33 Cubes~33hz Big Three done XS 1200 in the back
sean 371 Posted April 4, 2007 Report Posted April 4, 2007 Just resin is the easiest, and strongest. If you have the resin, or the money to buy it go for it. I use the shitty bondo brand resin, but hey, it works just fine for what i do. Now the bondo body filler's another story....but their resin and glass work fine A couple links to some box builds: Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI, Mini-Bump, Hummer H2, Ford F-150 My own car builds (current setup --- under construction): Overall Thread, Kickpods, Dash, Back Doors Subwoofer Wall
