when you turn on the a/c in my car, the air doesnt get colder, and i hear some kind of fluid (freon?) flowing around. the ac compressor clutch activates and deactivates perfectly fine.
i seen these a/c recharging kits at walmart for like $16 or so.
ive seen videos on youtube on how to do it but its confusing as balls when they have 15 clips, each 1 minute long, with no numbers indicating what vid is what.
Its really easy bro. Turn on your car and turn on the AC full blast. Open the hood and you will see the AC steel lines should have a blue cap on it more than likely . Plug the recharge kit into the AC line and fill it up. make sure you get a kit that has a gauge with it so you dont overfill the lines otherwise you can damage it. IF you have any more questions PM me and i can talk you through it
Team MaxRetribution
Si Vis Pacem Parabellum
It should be nothing more than buying a can and twisting it (usually) onto the correct pressure line on your A/C, there are two, a high and a low, if I'm correct it's the high pressure line. No offense (seriously) but it's as the easy as the instructions say on the side of the can. I've only done it once but it worked like a charm.
1990 Chevy Suburban (Big Booty Judy)
(4) Sundown Audio Zv5 18's
(1) Sundown Audio Salt 12K
(1) Sundown Audio SAX-100.4
(1) Sundown Audio SAE-50.4
(2) Crossfire ST-1 Tweeters
(2) Obsidian Audio ST-1 tweeters
(4) Sundown Audio Neo Pro v3 6.5's
Saving 2nd Bass
how many cans would i need of XXoz size?
edit: i think i saw 16 and 22oz cans.
Edited by Krannyman92
I can see you are determined to do this no matter what, but do yourself a favor if you ever want/need to have this done professionally in the future or need to have other parts of the system repaired. DO NOT BUY THE CANS THAT INCLUDE SEALER. You put the type with sealer in it and you do more harm than good.
Daily Driver 1999 Kia Sephia
Kenwood DNX-893s
Audison Bit One Processor
2 Dat 4.125's
Sundown Audio SCV-6k
Hertz hsk-165xl's Mids running active        Focal V30 Series Tweeters running active
Sundown Sa-8 v1's in the doors
2 Sundown Zv5 12's
Lots of Hushmat
Big 3+ and 3 + & 3- runs of Trystar 2/0
2 Dc Power Engineering 320 HP Alts
2017 Comp Vehicle
2006 Toyota 4 Runner
Kenwood Excelon DNX-893s        Audison Bit One HD DSP
4 Sundown Sa 6.5v2 Component Sets
Focal Access 6.5 2 ways
Sundown Audio Sax-50.4        Sundown Audio Sax-100.4
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
2 Northstar asmagm 480's
2 Dual 1 Sundown Nightshade v3 12's
2 Sundown SCV-7500's
All SMD Fuse Holders
Shitload Of Sundown 1/0
120 sq ft Second Skin Damp Pro
No, Its Not A Burp Truck!!!!
2016 Season 3rd place in Xtreme 1 At Finals
2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations)
2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL
David said:
audio is a lifestyle, not a hobby
newls1
I cant read a tape to save my life... 1/2's are ok, but other marks confuse me
kingsuv
only men who cant read a tape, take it in the ass
kingsuv
you sir, get a pink hard hat on jobsites
damn thanks for that tip. whats the sealer used for? i assume cracks and small holes in the system.
thats what its intention was for, but if you have a leak you suck moisture into the system. the sealer reacts with moisture to actually become a solid so any moisture that has crept its way in due to a leak will end up turning solid where ever the sealer and moisture meet at. Condensor, evap core, expansion valve, in an a/c line or where ever. once you haev that in there and it has gone through its chemical reaction and has become a solid, if it breaks loose anywhere you all of the sudden have a small bullet flying around in your a/c system unless it gets lodged in a filter or in the orfice tube if your vehicle has one. its been known to actually clog up an a/c system to the point that it wont cool anymore either after causing major restrictions throughout the system or gumming up a compressor to teh point it can hardly turn and almost locks up. Remember, an a/c compressor is a pump as is your engine. would you like your compressor or your engine chewing up solid chunks of shit? would be like dropping a bolt down the throttle body of your car.
Since i am getting all super descriptive here, let me clue you in on another thing with r134a. IT'S GONNA LEAK IN SMALL AMOUNTS NO MATTER WHAT YOU DO. Back in 96 and 97, the mobile air conditioning society had thier hands full testing what they thought were manufacturer defects on a shit load of under warranty compressors (r134a started to be used in the 93-94 model years). Come to find out, it wasnt a compressor problem at all. a r134a molecule is 1/200th the size of the old R-12 refrigerants molecule, therfore it escapes out of small seal sepage leaks extremely easy as well as general expansion and contraction due to temprature changes (think of what your underhood temps do during the winter months). Over the period of a year, the average A/C system on a newer car using r134a will leak 1 to 2 ounces. dont seem like shit does it. it wasnt with the old r12 stuff but a 1 to 2 ounce low charge can cause a 60-80 percent loss of oil movement through the a/c system. An a/c compressor requires oil just like the engine in your car does so whats gonna happen if you starve your cars engine for oil? It's gonna lock up eventually or become extremely noisy and work innefficiently.
The newer cars using r134a refrigerant are a critical charge as you can see if they stop moving oil significantly with being 1 to 2 ounces low. This means they are a critical charge system and have to be charged to exact specifications. The gauge on your can of refrigerant from walmart can get you close but not exact if you know what you are doing. The old pressure charts dont work for 134a. The old sight glass trick dont work on 134a. you have to completely suck the car down into a vacuum and refill it to get the charge weight correct or you are starving the compressor for oil even though you think you just recharged it how it should be because that cheap ass gauge said you are good.
Edited by kandiman71874
Kenwood DNX-893s
2 Dat 4.125's
2 Sundown Zv5 12's
Lots of Hushmat
2017 Comp Vehicle
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
newls1
kingsuv
kingsuv
so that liquid that comes out from the bottom of the cars when the a/c is on is normal? i think its water.
i do have an r134a system in my car. those kits they sell at walmart, you say i can get close to, but not perfect, to the manufacturer's specifications. will that hurt the compressor or other hardware/motors in the a/c system?
i guess i should just have a professional do it. i dont want to be driving down the road with no A/C, and the normal cool air is still warm
the condensation is normal, its supposed to sweat just like a cold coke bottle sittign on your desk for a while.
And if a just low charge of 1-2 ounces can cause a 60-80% loss of oil movement, yes it can hurt the compressor. bad thing is, you wont even feel it at the vents either.
Kenwood DNX-893s
2 Dat 4.125's
2 Sundown Zv5 12's
Lots of Hushmat
2017 Comp Vehicle
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
newls1
kingsuv
kingsuv
i also read somewhere that if an ac compressor cycles on and off more than once in 60 seconds, that there is too little freon in the system. is that true?
