Quick Amp Wiring Question
Not sure if I'm just tired or what right now but, I had a 2 channel amp bridged together with 2x 4ohm SVC subs. The amp is rated at 1000x1 @ 4 ohms bridged. I ran the subs in parallel so wouldn't that present a 2ohm load to the bridged channel? It's rated at 500 x2 @ 2 ohms so was I getting 500w per sub? I had it bridged at 2 ohms if I'm thinkin correct but may be wrong.
Here's the amp.
http://www.sonicelectronix.com/item_17600_...s+ZXi+1010.html
Old Setup
03 DurangoRF Power T1 6.5 CompsMids/Highs Amp: AQ4x90Sub Amp: AQ 3500.1DSubs: 2 DC XL 18sBox: 12ft^3 tuned to 33HzMechman 270 Amp AltXS 6500XS 3100 x2
Highest Score to date: 151.2 db @ Headrest
this is what you get when you wire them in parallel. so if you wired them to your amp at a 2ohm load, then each sub is only seeing 250w, 500w total @2ohm
edit: correct me if im wrong but 500x2@2ohm means that each channel sends out 500w for a total of 1000w@2ohm
Team Bass-Hz
I think whats confusing me is that it said its 1000w bridged @ 4 ohms. Well i had them in parallel and bridged so wouldnt it be bridged at 2 ohms?
Edit: i had them wired just like the picture in Enemy's post. I bridged the 2 channel amp into a mono amp.
Old Setup
The dilemma is this - your subs are single voice coil 4 ohm. You can't run the subs in parallel because it's only stable at 4 ohms mono. Your only option would be to wire each sub to a channel on the amp.
Enemy - you are absolutely correct, it would be 500x2@2 ohm, but bridged halves the impedence, so it's 1000x1@4 ohm.
2 - Audiopipe AP30001Ds
1 - Lanzar Opti Scion 600.4
4 - Lanzar Optidrive 1232D's
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar Opti 6C midbass
1 - Alphasonic PCT6551
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
1 - AudioControl Epic160
Okay so even tho i had them wired like that it will still be the bridged 4ohm load, I'm just wondering what kind of output I had.
So it was 1000x 1 = 500 per sub even though I had them wired to a 2ohm load and it says 1000 @ 4ohm
Old Setup
4 ohm dual voice coils would allow you to run each speaker at parallel and then in series to the amp for a four ohm bridged load, but according to those specs that max power is 1000 watts which leads me to believe rms power is way lower
-Mark
Host of "CarAudioFabrication" - YouTube Car Audio Tutorial Channel
Check out my forum section here on SMD for my builds and tutorial videos!
Subscribe on YouTube: http://www.youtube.com/CarAudioFabrication
It's 1000w RMS, theres a link on first post. Little overrated though.
Old Setup
  • Who's Online   0 Members, 0 Anonymous, 1296 Guests (See full list)
