I have a laptop that I want to make my carputer. I need a USB to RCA video adapter, but can't seem to find one. I did find one on another site, but when I clicked the link, I found that it had been discontinued and is no longer available (it was on Newegg.com, BTW). Can anyone recommend a good adapter? I also have a VGA output (I think it's VGA).
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
Anyone?
15.4" widescreen
What it does:
I'm trying to use my laptop computer as my carputer. I just need a USB to RCA video adapter so I can use my HU as a screen. I plan on later putting in a monitor in the center console, but for now, I don't have the money. I know what I'm looking for exists because my school has one. The only problem is, it outputs a crappy video signal, so I don't plan on using it.
Or that will work. Do you have any idea of the picture quality?
Edited by 1992Chevy
15.4" widescreen
What it does:
I see now reading > me
I thought you were trying to get an audio signal out of the usb to an RCA.
you are going to be limited by the video RCA though pretty bad quality.
video RCA < s-video < VGA < XVGA < DVI < and I think HDMI tops them all
video RCA is for SD tv's but I don't think it should be that bad on a 6-7" head unit screen.
how many pixels on your headunit?
Wouldnt be thehoe92 without teh purple
I'm not sure if my HU has s-video inputs, but I know it has RCAs. The resolution according to the manual, "336,960 sub pixels, 1440 (W) X 234 (H)".
15.4" widescreen
What it does:
ok its possible
look up evga UV plus its a usb video card
then you can get a vga to component or rca adapter depending on where u look
ok its possible
I already have a VGA ouput on my laptop so I don't need that card. I had to look to be sure it was VGA because I've only used it once.
15.4" widescreen
What it does:
