ok its possible
look up evga UV plus its a usb video card
then you can get a vga to component or rca adapter depending on where u look
it looks like its not a video card, it just allows you to hook up multiple monitors
DD M4
Rockford Fosgate P500-4
2 Rockford Fosagate T1675-S
XS Power D3400 Under Hood
XS Power D5100 in rear
Michael Singer 200A Alt
i know what your looking for hit ebay and type in vga to rca i think is what i looked up and got one its not a very good pic. quality tho but it works if times are tight
93 Civic Hatch
kicker components in doors
 [ak11667] 12:12 am: hook the speaker outputs up to your nipples and turn the gain all the way up
http://www.microcenter.com/single_product_...duct_id=0213567
hook it up to the VGA out of the screen run a 1/8th inch stereo jack also
SMD SuperSeller VerifiedJbondoXJames Shields
RCA will be fine for your tiny car screen. You said that was its only input, correct? If so, that's your limiting factor and no matter how high quality video adaptor device you get, you're still limited to using composite RCA video due to your screen.
2001 Chevy Blazer
(2) SAZ-3000Ds
(2) custom 18" Madmax subs in a second row wall
Rockford 600-4
Pioneer PRS components
Pioneer P800PRS deck
I know RCA is my limiting factor. I just want one that will give as good a picture as RCA can carry.
last I checked you can't get an audio signal out of a USB.
what exactly are you trying to do?
Actually you can with the right software. I have a couple USB headsets with mics, but they require dedicated software.
Any way, I found what I needed. Thanks for the help.
Edited by 1992Chevy
15.4" widescreen
128MB shared video memory
Windows 7 Home Premium 64 bit
What it does:
On a USB 2.0 Wireless card
