Small SPL Build For My ZX3 With NUMBERS!!!!!!
the only thing i would change about the box is maybe make it narrower, but longer....just enough room for the sub to fit without hanging over....if u can fit it...that way there is less 'dead space' on the wall where the port is...
but awesome numbers!
That was my origional plan to make the face just big enough for the sub but the box would have been too tall and ended up over the window line. It is actually going to be redesigned for about the same amount of airspace and 2 12's instead of a single 15. My goal is a 155 with a pair of 12's off around 9-10K watts.
Also thanks for the comment. I appreciate the feedback. I'll get some pics up of testing on Saturday.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
Couple more pics for you guys to look at. I've tested since I last posted and the numbers have jumped up quite a bit, I'll post them officially after this upcoming weekend since it is NSPL finals.
I did a brace in the box since I was getting a ton of flex when I burped it. Decided to glass over the brace and do another layer on the bottom of the inside of the box too. Enjoy!!!
Pics of box after it had been glassed and corners rounded over.
Posted Image
Posted Image
Muh brace for the sidez.
Posted Image
Posted Image
The brace glassed up.
Posted Image
Posted Image
New numbers next week and maybe a video. Depends on if you guys would consider it for System of the Month. If I get enough support and a nomination then we'll see what else I can do to impress you guys.
1 XS Power D3100
Audio Control LC6i
Stock Deck
Wow, tough crowd. Anyone think that I will break my old NSPL world record of a 152.2 sealed on the dash and a 154 in the kick?
1 XS Power D3100
Audio Control LC6i
Stock Deck
What sub are you going to use ?
What is this boxx going in ?
Sub is a Sundown Audio Nightshade dual 1 ohm, and I have done a 152.2 on the dash so far in my 2001 Focus ZX3 with 2 Sundown saz2000d's strapped at .5 ohms.
1 XS Power D3100
Audio Control LC6i
Stock Deck
i bet u gained a lil... :clapping:
Thanks for the interest Matt. You already know the most current numbers that I've done. I can tell you this the last time I was testing I had one of the 2000d's mounted to the box and I was doing my consistent number. Then all of the sudden the number dropped by .4db and we looked inside the car to figure out why. The amp fell off the box and made the score drop. I put the amp back on and the score came right back. So I figured by adding a brace that would definately help the score out some. I haven't tested yet since the brace has been added. I will probably try it out on Saturday before I compete.
1 XS Power D3100
Audio Control LC6i
Stock Deck
Come on man you have to test before the comp... not sharing the numbers I understand, but definetly yest so you kick ass....
2007 Great Wall So Cool
4-12' RE audio MX's
Stetsom 7k2D
6-Batts
3-Mechman 250 amp Rhino's
Wow, tough crowd.
yeah if you dont have oogles of money in the build with lots of custom work then it's hard to bring in the votes. you got mine tho. beast ass score off 1 15.
