ya thats what i was thinking since its puts out more then what its rated so my xls should have noproblem running 2 of these amps one for each sub
kia spectra 4 door
HU-a kenwood kdc-692x
optima red top under the hood ( kinetik battery or powermaster in the back )
Iraggi 260amp H/O alternator
1 set of knu kandy 1/0 guage wiring kit ( 2 more sets coming )
front speakers -
back speakers -
2 12" lv 4's with lvl 5 softparts ( going to be 4 in near future)
Sundown 3500d( going to be 2 sometime )
i have boughten from - Bass14(smd), ddbump(caraudioclassifieds)
We dont do birthsheets <there useless>its rated @ 2000 @ 1 ohm @ 12.8 volts....underrated
Birthsheets are like drivers licenses, just cause I have one doesn't mean it's any good
1990 Chevy Suburban (Big Booty Judy)
(4) Sundown Audio Zv5 18's
(1) Sundown Audio Salt 12K
(1) Sundown Audio SAX-100.4
(1) Sundown Audio SAE-50.4
(2) Crossfire ST-1 Tweeters
(2) Obsidian Audio ST-1 tweeters
(4) Sundown Audio Neo Pro v3 6.5's
Saving 2nd Bass
According to my math, they sould do just under 2200 at 14 volts even @ 1-ohm.
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
:blink::unknw::unsure::huh:
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
LOL, I'm somewhat of a math geek. But of course, I based the math off of the 2000 watts @ 1 ohm that I read above.
Edited by 1992Chevy
15.4" widescreen
What it does:
Well please explain.
I do box designs.
yea im curious as well.
to the OP, you wont be disapointed with the saz 2kd
i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
Ok.
2,000 watts at 12.8 volts. So, 2,000 watts / 12.8 volts = 156.25 amps.
156.25 amps * 14 volts = 2187.5 watts.
Like I said, this is based off of what was said above. Plus the higher the voltage, the higher the output. And one more thing, this is not perfect, the amperage changes with the voltage. It usually goes up. I'm not sure how much and can't calculate how much. So the above is an absolute minimum.
15.4" widescreen
What it does:
  • Who's Online   0 Members, 0 Anonymous, 1611 Guests (See full list)
