loganberry's f150 build-- big changes coming soon
clip depends on many things, but you will stay away from it with higher the voltage you can keep on the input of amp(s). Every amp will clip if you want too much from it, hope that is not the case here
Got carbon fiber dust cap???
How the wire is on the terminals of the amp, I stripped the screw holes and its glued in there, tommorro I'm gonna get bolts that fit tight inside the holes and use ring terminals/washers/nuts on the amp, then solder the bolt in..see if that fixes it
My F-150 Build
GET ON THE BANDWAGON
what if they tried messing with the amps when the subs werent louder :ehh: hahah jk :pardon:
sounds good, i was thinking you will buy batts to fix this, but i see now you had this plan anyway
Logan, look at the rf 360s or the audison, they arent cheap but they are waaay better then the maxxlink, can also help tune the system to sound better
Agreed with David. Both are nice and will clean up the overall sound
Audison Bit-One has my eye. Money is currently being put to the side just for that. Maybe James will sell me his when the money's there. :peepwall:
SMD Super Seller/Buyer
Audison----Hertz----Rainbow
  • Who's Online   0 Members, 0 Anonymous, 1546 Guests (See full list)
