Hobby's 2004 Silverado Ex Cab
Awesome choice my good sir. Sunday is going to be huge man. I think I'm going to crank the hell out of my amp. I have the settings marked, so I should be ok. Thanks again for helping me scope it Ed
My bass is louder than your mom...
DC Level 4 15" with Level XL soft parts
Planet Audio BB2400.1
Pioneer DEH-6000UB Head Unit
950 amp Kinetic Battery
is that just resin on the outside of the box or some kind of stain? looks classy
The screw holes are filled with Duraglass and the box is finished with Polyurethane inside and out.
i might have to steal this.. i like the way that looks
  • 1 month later...
deadener or a welder haha
R.I.P!
(Nov-29-2009)
92 explorer
current build
Yea I have 2 layers of deadner on the roof and it still does a pretty good wave on the right songs. I used RamMatt on most of the truck. I have about 1 1/2 rolls installed. All the doors inside and outside, back wall, some of the floor and the whole roof. I also foam filled all the roof supports with GreatStuff.
It helps but once you reach a certain point all hell breaks loose on these extended cab roofs. Things are like tin cans.
Thanks for the info. How would i go about bracing it? Could you supply a link or some info? Only goin to be running 2 saz3000ds. Deadener?
I run 6 layers down the center of my roof and 3-4 down the sides (Secondskin), wood shims to fill the gaps between the braces and the roof, plus GreatStuff. My roof used to wang, now it still moves, but maybe 1/5th as much.
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
Second Skin
2 270a Mechman Alts
