I really want to run a double din but I'm in the same situation as steve was. just wondering if anyone wanted to tackle this project? just PM me if you are interested in doing it
here are some pics for reference
Ok, here is the double din Alpine goin' into the dash....not done yet, i got tired and i gotta go to work in the morning...i shouldnt even be posting pics, but these ones are sorta worth posting. :)
Here is what i started with...already moved the HVAC controls
hmmmm how am i gonna pull this one off...
gotta take a looksy at it and see where i want it.
right here is good :)
Ok back to what i was working on.....time to make the wood frame fit in the plastic dash piece (which by the way it was fun to butcher a brand new $120 piece of plastic) :P
After making a few marks, time to cut the plastic to fit.
Oh ya, i filled the gaps with a cardboard backing so the Urethane would have something to sit in
Mixin up the last of my Urethane supply....gotta order up tomorrow!
AFter lots of sanding (and more to do) here is what it looks like
You get the idea...im tired, dirty, smelly and 2 hours past my bedtime.....nite-nite all
Edited by doug118
is your car also a civic?
same as Steves....he was trying to get Steve to trade for his stock, + some cash. must not have heard back from him.....
06 2500hd, 6.0L, 4l80e, 4wd, (muah work truck)
7" BDS HC lift kit
(5) 37x13.5R18 Toyo Open Country M/Ts
(5) 18x10 Moto Metal MO962
tablet in lieu of deck
blue tooth interconnect to soundstream eq (for volume control and bass control)
4 Alpine type r 10's
6 cubes net, 80sqin's port, tuned to 33hz
2 brutus brx5000.5's
2 pairs 3" polk audio for a pillars
4 pairs polk audio 6.5 comps
1 pair 8" polk audio for mids
2 xspower d3400 batteries
.....learning alot from meade and his circle of some of the baddest installers ive seen- thanks guys, for not being so cocky and posting the way it should be done!
P.S. Thanks Steve....for the demo!!!! loud as fauk!
yep same climate control
aha, you beat me to it....sorry :spiteful:
7" BDS HC lift kit
there are a few ways to do this, you can use the wood like shown or use the radio trim. then you can use a two part epoxy or make a abs sludge (abs plastic shavings and acotone) then fill the gaps in around the trim and sand, if you fiberglass it you have to drill holes so the resin has some thing to grab on to, resin dose not stick to abs
id like to hear more about the abs shavings and acetone therory i have never heard of that or some pics would be cool
Roseville, CA
Isn't that Steve Meades' civic?? I could be wrong. Look similar.
