XS Power
also, you could contact DC Power or Mechman to see if they can make an alt for your car...
AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
Do you know what size the stock battery is? I can look it up at the office tomorrow and let you know what fits!
i have no clue what size it is it's probably what ever the hyundai aonota has, because they are basically the same car.
i contacted dc the other day. Damn, i didn't know that alts were that much. they had one that would fit my car, but they qwould have to do some work on it. it was a 270xp.
Your car uses a group 124R battery from the factory. The measurements are essentially the same as the D3400 except the positive is on the opposite side. Many times you can drop a D3400 in that spot and use the 555 I-BAR kit with the starting terminals closest to the rear of the battery and the cables will still reach and work just fine ;)
XS POWER Batteries, Chargers & Accessories
888-4XS-POWER
how much does a d3400 cost. i can only find d3100's. will a d5100 fit.
The D3400 is $239... a D5100 will probably fit just fine.
888-4XS-POWER
which is better the 3400 or the 5100r. also. when i run the second batt in the trunk, should i connect the positive and negative from the front batt or just the positive then ground the neg in the back to the frame.
The D5100r would work well because it should fit and the terminals are reversed so all your wires will hook right up to problems(if you need the reverse like stated above)
thanks man, i'll look into that. do xs batts come with post or do i have to get my own.
ummm I think some of the more expensive ones do? Sometimes I see them coming with posts but I think for the most part no.
Antone else know? :search:
EDIT: if you need to know any specs
http://www.4xspower.com/audiobatteries.asp
Edited by BulletInjection
