First time on the mic... Not looking good.
GoldElks
i would never let some shop test my truck for 10 minutes on their mc...IM doing the testing if that was the case...if i were you id been like hey ill give you 15 bucks if i can have 20 minutes on the mic.
also big 3 and batts will make a HUGE help. as for the box...i think thats way too big. size her down a little.
NoFearX18 said:
trainman0978 said:
I don't care how bad the box is or what, that score is way too low. IMO as mentioned above they're trying to get you to buy new gear. Go to a show, get it done on a Termlab.
10.x volts fo' life!
You need more power. You are right you should be hitting over a 140 on AC but there is a 2-5 DB difference between AC and TL. A smaller enclosure might help you out or hurt you it is just something to play around with.
(ITS ALL IN THE BOX)
- 1998 Ford Mustang -
Time to rebuild.
4 15s and alot of power
TEAM DTF
Today I metered at a 135.9 at 40 hz sealed on the dash. Now I am not wanting to compete I just thought my 2 15s would get at least a 140. It was on an AC not a term lab, i don't now how much different the AC and TL are but i cant imagen it being that big of a difference in score. Any thoughts on the score or possibly something that stands out to anyone?
Car is a 2005 trailblazer with no deadening.
System.
Stock electrical.
Stock head unit.
2 Kicker L5 15s
11.5 cu ft tuned to 35hz.
1 Crunch 1500.1 wired at 2ohms.
Some of the things I want to do are...
Install a line driver, any thoughts on that?
Do the Big 3.
New battery upfront.
There's your problem. The 1500.1 only outputs 375 x 1 @ 2-ohms. A GPV2000.1 would be a lot better if your on a budget.
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
System.
Stock electrical.
Stock head unit.
2 Kicker L5 15s
Do the Big 3.
my two 10's hit 141 on the TL so theres definitely something wrong with your setup.141 on the TL
(2001 Dodge Durango R/T)
1- XS Power D2700
1-Alpine CDE-HD149BT (Head Unit)
1 pr.- Focal Polyglass 165v30 (Front Stage)
1 pr.- Hybrid Audio Technologies C61-2 (Rear Fill)
1-Kenwood Excelon XR-1S (Sub Amp)
1-Kenwood Excelon XR-4S (Mids-N-Highs Amp)
2- JL 10 W3v3-4 (Subs)
-2.3 Cubes tuned to 32 hz
1-1/0 ga. & Big III in 1/0
140 @45 hz db drag legal
(2008 Toyota Highlander Limited ---build in the works)
1- Kenwood DDX470 (Head Unit)
1 pr.- JL C3-650 (Front Stage)
1 pr.- JL C2-525 (Rear Fill, may upgrade to 6.5" C2 or C3 instead)
1- JL XD-400/4 (Mids-N-Highs Amp)
1- JL XD-600/1 (Sub Amp)
1- XS Power D3400
1- JL 10w3v3-2 (Sub)
1- JL 2 Ga. Amp Kit
1- BIG 3 in 1/0
1- self-built Fiberglass sub enclosure
after looking at your pics again i think alot of your problem might be because the port is to close to the trunk and it aint giving the air a chance to bounce off the trunk so its just sitting in that space and kind of keeping the air traped down at the bottom of the box between the box and trunk lid. I think that is alot of your problem so try moving that box towards the front of the car a little and see what it does
Time to rebuild.
TEAM DTF
I would like to say thank you guys for all the help. I AM changing the amp (Kicker 750.1 *i know this is odd a side note in a side note lol... just to clarify when running 2 subs in series to a mono block, you do not divide the power in half.. correct? Both subs will get the X amount of power?*) Back to the topic. I AM scaling the box down to around 8.5-9.0 cu ft and looking at a 37 hz tuning. Okayyyy I am also looking at a batcap, any reviews on these would be greatly appreciated! I dont have the money to go all out with the electrical, New HO alt, new bat in front, new bat(s) in the back, blah blah. So i am hoping the batcap will be an ok alternative for me.
If you run, let's say, 750 watts RMS x 1 @ 1 ohm into two subs, each sub sees half that, or 375 watts RMS per sub.
15.4" widescreen
What it does:
Ok so one last example just to clarify lol...
1000.1 at 2ohms going to 2 subs (being the amp puts out 1000 at 2ohms). Each sub will receive a total of 500 watts RMS. Correct?
If this is the case I need to read more, being 15 i must of just assumed and hoped. All well better to learn this now then later. http://www.stevemeadedesigns.com/board/public/style_emoticons/default/dirol.gif
(btw i umpired all summer to get the money for the system lol, many people jump the the conclusion its all daddy and mommy... if they had it their way The trailblazer would still be 100% stock and we all know thats no fun)[/size]
