troy Posted August 28, 2009 Author Report Posted August 28, 2009 where is the diagram of how to strap amps? i seen it the other day but idk where Quote retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs
Nightshade Posted August 28, 2009 Report Posted August 28, 2009 where is the diagram of how to strap amps? i seen it the other day but idk where In your 1500d manual. It's very easy though. All you need to do is take some 8 guage and run it from the -'s on each amp to one another. Then take a single channel of an rca and run it from the Br in on the master amp to the Br out on the slave amp. Make sure the rca's are in the input on the master amp. Then you use the + terminals from the mater amp as the + wire for the subs and you use the + terminals from the slave amp for the - wires to the sub. You better look at a diagram though. Quote 2013 VW Jetta GLI 2.0 Turbo 1 Sundown Audio SCV2000 1 Sundown Audio X15 V2 1 XS Power D3100 Audio Control LC6i Stock Deck 146.4 sealed on the dash at 37hz 2001 Focus ZX3: RETIRED Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore ChampionHighest NSPL Scores to date:154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz155.2db unofficial on dash at 43hz
troy Posted August 28, 2009 Author Report Posted August 28, 2009 doesnt really sound that hard though. Quote retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs
Nightshade Posted August 28, 2009 Report Posted August 28, 2009 doesnt really sound that hard though. It's not, it's just better to have the diagram right there when doing it. I just strapped my amps for the first time about a month ago and I had to have the manual in the car when I was doing it to make sure it was done right. Quote 2013 VW Jetta GLI 2.0 Turbo 1 Sundown Audio SCV2000 1 Sundown Audio X15 V2 1 XS Power D3100 Audio Control LC6i Stock Deck 146.4 sealed on the dash at 37hz 2001 Focus ZX3: RETIRED Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore ChampionHighest NSPL Scores to date:154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz155.2db unofficial on dash at 43hz
troy Posted August 28, 2009 Author Report Posted August 28, 2009 (edited) ok i got another question. would it be better to get 4 amps and run a pair strapped at 2 ohms on each sub or to get 2 amps and just run one amp to each sub at .5ohms??? iirc higher ohm loads draw less current and have less distortion right?? also warrenty still applies at 1 ohm right?? but would i see the same power out of 1 amp at .5 vs. 2 strapped. Edited August 28, 2009 by troy Quote retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs
bkolfo4 Posted August 28, 2009 Report Posted August 28, 2009 ok when putting a amp on each coil of a dvc sub how do you set the amp so each coils is recieving the exact amount of power? Just FYI. . .It really does not matter if they are getting the same exact amount of power. . . ok i got another question. would it be better to get 4 amps and run a pair strapped at 2 ohms on each subor to get 2 amps and just run one amp to each sub at .5ohms??? iirc higher ohm loads draw less current and have less distortion right?? also warrenty still applies at 1 ohm right?? but would i see the same power out of 1 amp at .5 vs. 2 strapped. If this is a daily driver, and you have the extra money, go for 4 amps. . .They more than likely are not going to double their power from 1 ohm to 0.5 ohms, so the 4 amps will be more power and less stress on the amps. Or sell the 1500's and get a pair of 3500's. Quote Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
Derrick824 Posted August 28, 2009 Report Posted August 28, 2009 Link to strapping amps with some nice pics. http://www.sundownaudio.com/index.php/freq...-questions.html Quote
troy Posted August 28, 2009 Author Report Posted August 28, 2009 Link to strapping amps with some nice pics.http://www.sundownaudio.com/index.php/freq...-questions.html yep thats exactly the page i was looking for. but i see 2 outputs coming form the amps now. so what would the impedance of the two outputs?? 4 ohms Right? the tied internally to 2ohms ??? you could only have one output at 2 ohms correct?? Quote retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs
