Hello, I'm still kinda new here, so I am going to have some questions along the way, this one might be a dozey for ya'll, how do I find my amp effeminacy rating.
These are the facts that I know about my amp,
Lanzar Digital Mono Block Amp
1 x 400W RMS @ 4 OHMS
1 x 800W RMS @ 2 OHMS
1 x 1000W RMS @ 1.3 OHMS
1 x 2000W @ 1.3 OHMS
1 x 4000W Bridged Max Power @ 2 OHMS
Mono Block Subwoofer Amplifier
1 Ohm Stable
MOSFET Power Supply
PWM(Pulse-Width-Modulated) System
Glass Epoxy PCB With SMD Technology
Gold plated RCA Inputs
Custom Terminal Block for Speaker Connections
Thermal, Overload Short Protection
Variable Subsonic Filter(15Hz~40Hz,24dB/Octave)
Phase Control 0-180 degree
Input Impedance:10K Ohms
Soft Turn On/Off
Heavy Duty Power Coated Heatsink
THD: 0.1%
S/N RATIO: 90dB
Input Sensitivity: 200mv~8V
Freq. Response: 10Hz~150KHz
Remote Bass Control
Fuse: 30A x 4
I need a little help figuring the numbers, I am running it at 1 Ohm, and should be around 1300 wts. Any help would be appreciated! I guess I want to know so I have a better idea what the numbers going to my subs are, to deceied to upgrade to another another amp, or bridge this one with another.
03 GMC Sierra Z71 Ext Cab l 2 15" American Bass XO's l 1 Lanzar HTG2600 l AudioVox 1510D In dash DVD l KnuKonceptz Wiring l Big Three Done with KnuKonceptz KLMX 1/0 l Infinity Reference 6022si 6-1/2" Front Door Speakers l Upgraded to 145A Alt from 105A Alt l Custom Box 2^3 under the rear bench with resined bottom, and about 4 lbs of polyfill
1 Ohm Stable
Okay, you didnt include a model or anything but after some looking i wasnt able to find any eff. ratings. imo its lanzar, and efficiency wont be the best.
are the output ratings a typo? it might be 1x2000 @ 1 ohm & 1000 @1.3.
Lol it has SMD technology
& by bridging it with another do you mean strapping 2 amps?
Current System:
Pioneer 6900 HU
Front Stage: (for now)
Soundstream tarantula 5.25 in the doors
Soundstream tarantula 4x6 in the dash
Kenwood 400.4 for mids & highs
Bass:
4 Soundstream RW-12's
2 Power Acoustik Stax 4000/1D's
single chamber box, 2.65 cubes.
Currently under the knife being bagged
Rebuilding err'thang
seems like a lot of power out put (watts) for only drawing 120 amps ( 4 30 amp fuses) of current..
i cant remember if this is right but If an amp is 100% efficient (NEVER HAPPENS) 120 amps of current X 14.4 Volts ( also never happens with stock electrical ) = 1728 watts In a perfect world, which we are not.
So 1728 X .8 ( assuming 80% efficient) = 1382 a ROUGH estimate? If any of this formula is even correct. i Cant remember lol
lower tuning is just hard. I was surprised how loud 145 sounds at 35hz, and how quiet 145 sounds at 50hz.
-= 2005 Tahoe LT =-Head unit: Pioneer AVH-X5500BHSSource: iPad Mini in dash
Subs: 2 T1 12's
Sub Amp: T1500-1bdCPWire: Rockford Fosgate 1/0 awgSignal Cable: MonsterFronts:Stock Bose for now:)Rears: Stock Bose for now:)MIds/High amp: Stock Bose for now:)
2005 Tahoe Build Log: http://www.stevemeadedesigns.com/board/topic/172529-2005-tahoe-my-17th-vehicle/
2001 Monte Build Log: http://www.stevemeadedesigns.com/board/topic/160030-2001-monte-carlo-my-16th-car-lol/page-2#entry25309381997 Tahoe Build Log: http://www.stevemead...oe-6-15-rf-15s/2001 Impala Build Log: http://www.stevemead...katzkin-inside/SMDSig3-26-12.jpg
Since it is a cheaper amp... the 2000 at 1.3 is MAX... not rms... and by bridging.... it means bridging the channels... not strapping....
No its a mono block, so I mean strapping, sorry I did not really know the term until after I posted this.
Sorry the model is a HTG2600D
My math came up with about 1300 wts rms as well, so by me having 2 500wt rms DVC subs, I need about another 700 wts, so I need to get another amp, or buy a 2k rms amp..thanks for making sure I was thinking the right way with my numbers..
Edited by z71kris
I'm a bit worried that you want to send 1kW RMS to a sub designed for 500W RMS. If you are running 1300W RMS out of the amp, each sub is seeing approximately 650W RMS as it is.
Edited by 1992Chevy
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
doesn't each VC need the 500?
No, 500 is what both VC will take combined. Or each VC will take 250.
15.4" widescreen
What it does:
good to know....that would have been not good, I have always assumed that it was each VC the power rating was stating not a combined....
Edited by z71kris
No, it's definitely combined unless specifically stated otherwise.
Good luck with the system.
Edited by 1992Chevy
15.4" widescreen
What it does:
