Well I have a problem with noise going through my subs with CD's and switching between modes on my HU. Vid will be up soon. Whenever I turn my lights on, signal, turn air on, anything it makes noise through the sub. It cant be an alt problem because I have my car off in the vid and it does it then. I have been told that I should ground my HU to my chassis. Which Ground do I use, the one straight from the Hu or the harness or both?
1995 Ford Mustang 3.8l V6 5 Speed
Plans:
  • 2 12 inch dc Level 4s
  • DC 2.0k Amp
  • KCA 1/0 Power Amplifier Installation Kit
  • 220 Amp Alt
  • XS Power 12V D925 AGM Battery
  • Stinger Volt Gauge
  • Rockford Fosgate RCAs
  • Box built from birch. Probably tuned to 32 Hz
  • 0 gauge wiring for extra battery
  • Dynamat
“I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.”
Al McGuire
“The only mystery in life is why the kamikaze pilots wore helmets”
Al McGuire
remember this always
Close only counts in horseshoes and hand grenades
You need to make a new ground wire at tranmission tunnel are somewhere on the floor pan. Make sure before you drill a hole for a screw there's nothing that you will be drilling into look first. Or some people run a ground wire from the negative post of the batriey. OH The ground wire from the harnes goes to the ground on your radio. Thats pluged into the factory harness. That should work if not make a new ground.
Ima run wire fron the two connected to my amp ground. I will let yall know how it goes
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
I have had this problem in the past. After grounding my rca's no more problems pioneer head units are bad about it.
J&T DESIGNS
M5
4 Audioque 15's copper coils dropping Audiopipe, and picking up DB DRIVE OKUR
Powermasters
XS POWER
Dropping MaxxSonics
Pioneer
well, I tried and no difference in sound. Should I just try a ground loop isolator?
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
Well I started my car today and It just went away problem solved...... I guess
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
Started it again 10 min ago and its back. I do have a sosche sound module for my lights and door open that stuff http://www.walmart.com/catalog/product.do?product_id=5691045 . Could that be the problem?
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
if its not wired or grounded possibly..
03 GMC Sierra Z71 Ext Cab l 2 15" American Bass XO's l 1 Lanzar HTG2600 l AudioVox 1510D In dash DVD l KnuKonceptz Wiring l Big Three Done with KnuKonceptz KLMX 1/0 l Infinity Reference 6022si 6-1/2" Front Door Speakers l Upgraded to 145A Alt from 105A Alt l Custom Box 2^3 under the rear bench with resined bottom, and about 4 lbs of polyfill
tried every possibe way and nothin. Should Ijust get a new hu
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
  • Who's Online   1 Member, 0 Anonymous, 1463 Guests (See full list)
