O.K. so this is something I have been doing for the last 2 weeks in between the benz.
trunk and frame work
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
A little fleece
Posted Image
Posted Image
Resin
Posted Image
3 layers of glass mat
Posted Image
Some people need a sympathetic pat... on the head...with my hammer
Scientia est Vox
DONT BE AFRAID TO USE THE SEARCH BUTTON!!!
SMD SUPER BUYER/SELLER
Test fit of the sub
Posted Image
Posted Image
All smoothed out
Posted Image
High build
Posted Image
Primer sealer
Posted Image
Some graphite Gray to color match the car
Posted Image
Clear Coat
Posted Image
Gear Installed: Memphis 15-MS124D 12" Dual 4 ohm Sub wired to 2 ohms
Memphis 16-MCD500 Mono Block Amplifier 500W x 1
Posted Image
Posted Image
Posted Image
I will Post more when I get the car back to finish the install
Scientia est Vox
Guest Nismofreak
Just messin with you man. GOOD JOB!!!!!!!
that DOES look pretty nice!! pretty simply put!! i hope to do something similar to that!! looks pretty sweet!!
The only concern/question i have, is.. it is a sealed... looks as tho its a small "box" for it.. or does it really matter the size of the "box" if its sealed??
like would a large box and small box both SEALED sound relatively the same..?
06 SCION tC
Looks like he wanted just a little more thump. Very nice work man, you have major skill. How long did that take you in man-hours?
1- T1000.1bd's
3 Maxx 29 deep cycles
4 runs of 1/0 gauge
-Big 3
All in a CAR.
Its actually just under 1 ft cu after displacement sealed (.983)so I just stuffed it with poly fill. I hooked it up to a battery I have and to the garage stereo and it has real good sound in the "open" garage that memphis takes 1 cu ft
Scientia est Vox
