Bad to put a fuse block in 20" away from batt?
I want to put in a speaker amp and I only have enough wire to go about 20 inches away from the battery. Would it not protect it if it shorts for any reason.
If you don't get it this is what I mean. Batt-----------------fuse-----------------------------------...amp
...............................................................20" ^...fuse block ^........other wire to amp^
Pretty much whats the max length from batt to fuse block?
Thanks Guy's. Oh and sorry for the noob question.
Edited by brsteinbach
2 Infinity Reference 1252w 12s
4.2 cubic foot box tuned to 28hz
Sub amp: 1 Profile AP1200
Speaker amp: 1 Sony Xplod XM-504z
Kenwood eXcelon KDC-X492
4 and 8 Gauge Knu
Big III In 1/0
All in my 90 Accord
f05112e8-c6ca-4f78-9a8d-47be99303c8b_zps
Diamonds are forever, but 9's end that shit fast....
no such thing as a noob question thats how we gain knowledge by askin not sure what your asking do you already have an amp in use and you want to add another one?
06 chrysler 300C Hemi
one mmatts dreadnaut 15 powered by a planet audio vx 2200d
fosgate p200 running planet audio 8" midbass drivers and super compression tweeters
stock battery and a stinger spv44
Irragi 300 amp alternator
big 3 1/0
http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
I only have a sub amp and that all installed fine. but I have a speaker amp sitting mounted on my amp rack but isn't hooked up.
I heard when you put in a fuse block your only suposed to cut the wire about 12" max when running power wire.
In my case I only have enough wire to get about 20 - 25 inches away from my battery so then its about ten more inches away then recommended length.
I can't explain it very well sorry.
4 and 8 Gauge Knu
Big III In 1/0
All in my 90 Accord
the distance is irrelevant, all your doing is fusing it right after the battery so if the wires get pinched and grounded between the fuse and amp, it will blow. you can put your fuse right before your amp in the back. But keep in mind, the distance from the battery to the fuse, if shorted, will not blow the fuse and could start a fire
I'm confused as well about what you're asking. If 12" is recommended, then can't you just cut your wire to 12"?
edit:
Ahh now I think I get what he was saying.
Edited by sayhuh?
10501650_10203332501847103_1859383749711
Blown
Ok cool. Thank you.
And thanks from everyone else.
4 and 8 Gauge Knu
Big III In 1/0
All in my 90 Accord
20'' is fine usually most recommend 12" to 18" from starter batt it shouldn't be a problem.
2007 Chevy Impala LS
1 Crescendo 3KWP
1Crescendo C1000/4
2 DC lvl 4 15's with lvl5 dual .7 coils
1Audio Control Matrix
1 Pioneer P880PRS
1 300 amp Iraggi alt
All power runs done with Knu flex 0/1 guage
1 optima yellow top under the hood
1 XS 5100 and two Deka's in the trunk
4 Crescendo MP-8 mid bass drivers
2 DB Drive p5 5 D Pro Audio tweeters
you dont need to add another fuse just a distribution block to tie in the amp to the power wire from the battery Id also suggest upgrading your power wire to a min 4guage and the fuse at the battery and down the road you might wan't to consider upgrading the battery up front and adding another in back with the amps and if you have'nt done the big 3 good time to do it
big 3 1/0
The "wire" link between the battery and the fuse is the dangerous section. If this link should get crimped or ground out somehow, ...say good by to something!
You learn the hard way.
Keep that fuse as close as posible and keep the wire free from getting crimped. Also keep it fasten down somehow.
93' Ford Aerostar
Alpine head unit
4-5.25 MB Quarts
20-10" pyramids super Pro
1 Lanzar amp
  • Who's Online   1 Member, 0 Anonymous, 1355 Guests (See full list)
