h.o. alt with no system??
No, it would not
Car
1996 Sable LS
8,000K Bi-Xenon HID's
Pioneer Premier DEX-P1R
Diamond Audio D351, Diamond Audio D362i, Diamond D3TAK off Kicker ZX200.4
Custom 15" 13w7 motor, 3.5" aluminum coils dual 1 ohm off NV-AM25001
Dynamat Dynaliner Second Skin Damplifier Pro
Stock 130A Alternator
My Build
Truck
1995 Ford F-150 Flareside XLT
10,000K Bi-Xenon HID's, 15,000K Bi-Xenon HID's
Kicker KS6502, KS400 off Pioneer Premier PRS-D4100F
Truck Build
Ref(s) Rogers, Jared, Mikesmith0890, Twigz, DHFHades, BASS14, Solo_X18, mrafrica, camino_1to3, kickerassman
[speakerman9000] 5:43 pm: if sony sucks so bad how come my amps still work when i had 3 12s on it
[capalass23] 11:27 pm: wow u grand man poopin out babys like hto cakes
[KevinniveK] can u have sex later please hes helping me
i dont think so i mean it'll jsut be more volaage for your cars electrical so youll have more pwoer for like say rolling windows down and AC on blast and al that with no drop.
That's why they don't deliver.
Yer ass better go sit along the side of the road and wait.
You can't expect them to travel up some dirt road in a hick / back woods town. Thats how horror movies start :D
I explain things very simply and use analogies in terms of Pickles, and grape drink, pool noodles and jackhammers...if you can't put 2 and 2 together there man, There simply is not much more I can do.
the alt will only put out what it needs to. Its not like it will be doing 200 amps constantly. It registers how much power it needs to put out and then does it. Thats what one of the wires on the alt does. Unless it is a 1 wire alt that is.
EDIT: i cant spell
Eclipse cd7000
your alternators voltage regulator will govern the output (predetermined*) as it measures the battery and alternator stator voltages and adjusts the output of the rotor field accordingly... in nut shell...
now if your regulator takes a dump then you could be in trouble, but depending on the design and who is building it... or the vehicle manufacturer some have warnings in the cluster when the alternator is supplied by the "L" output for the warning lamp. most vehicles now a days has it built into the cluster and not in the alternator.
*predetermined output when designing if built in regulator or an external adjustable regulator. most are set to between 13.4 and 14.4, but I have seen some at 16 volts also.
so now you now the basic reason why instead of just getting an answer of yes and no
Also Mercedes-Benz has the most technologically advanced automotive alternator in the world in the new 2010 E class. It is pretty cool... damn Germans!
SMD SuperSeller VerifiedJbondoXJames Shields
i dont have a system in my car and have a upgraded alt. i also made an adjustable regulator for the alt and i charge the battery to about 15.4 sometimes.
no problems
DC.jpgDC POWER
Any more info on those mercedes alts? *interested*
2001 Chevy Blazer
(2) SAZ-3000Ds
(2) custom 18" Madmax subs in a second row wall
Rockford 600-4
Pioneer PRS components
Pioneer P800PRS deck
computer controlled since an alternator is an alternator
excerpt
Alternator: power from braking energy
Each time the car is braked, kinetic energy is converted into heat and therefore goes to waste. This is why the new E-Class Coupe incorporates efficient alternator management. This means that, whenever the engine is coasting and whenever the vehicle is braked, the voltage level in the vehicle electrical system is increased and the battery is charged. This increased alternator load assists the driver with braking and also helps to recuperate part of the braking energy, which is converted into electrical energy. This is why experts refer to recuperation. Conversely, the alternator switches to no-load operation in certain situations – for example when accelerating or when the battery charge level is high – thus relieving the strain on the drive system. This process saves fuel to the tune of around 0.1 liters per 100 kilometers (NEDC) and up to 0.2 liters per 100 kilo-metres when in city traffic, where coasting and braking are more frequent than in the NEDC test cycle.
  • Who's Online   0 Members, 0 Anonymous, 669 Guests (See full list)
