Yes I know that bypassing the parking brake is dangerous and I should not have DVDs going when I am driving, but I want to do it because I am taking a 6 hour trip soon and I will have passengers along for the ride. The HU I just bought was a pioneer AVH P6500 DVD I bought it off cnate777. It is not here yet, but I want to be ready when it is. What do I have to do to get this to work? Is there any way to do it without a switch? If not how do I wire it?
Edited by marquettefan247
1995 Ford Mustang 3.8l V6 5 Speed
Plans:
  • 2 12 inch dc Level 4s
  • DC 2.0k Amp
  • KCA 1/0 Power Amplifier Installation Kit
  • 220 Amp Alt
  • XS Power 12V D925 AGM Battery
  • Stinger Volt Gauge
  • Rockford Fosgate RCAs
  • Box built from birch. Probably tuned to 32 Hz
  • 0 gauge wiring for extra battery
  • Dynamat
“I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.”
Al McGuire
“The only mystery in life is why the kamikaze pilots wore helmets”
Al McGuire
remember this always
Close only counts in horseshoes and hand grenades
I have a pioneer 6600 flip out, find the wire that suppose to go to the e-brake, then hook that to the black ground wire you ground the deck with, NO SWITCH needed. Only cheap ones i think use switches lol then it should come on mine does, hope this helps.
that will work and nothin will break either. have a safe trip bro!!!
I know a lil about everything so dont call me Mr. Know it All.
thanks guys , I will jmitch, hopefully will get this deck by wed and were leaving friday so hopefully I will have it by then and the big 3 (thanks Scottie)
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
some decks require you set/unset the parking brake to get the video on. those are the ones that need a switch. a few pioneers i have seen the pb wire needs to be grounded when the unit is hooked up to power. just ground the light green wire and if it doesn't work, unhook the wire turn the radio on then ground it.
also, i didn't tell you that.
CAUTION!
POOR INSTALLATION MAY SHORT BOTH YOUR SYSTEM AND WALLET
parking break wires ive dealt with has been pink, or pinkish in color.. but yeah just ground it and make sure it says brake on it
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
most pioneers you wire up a relay to double throw the ground.
Connect wires as follows on relay:
Pin #86 - Amp remote from your radio (blue wire)
Pin #30 and #85 - to a chassis ground (metal dash bracket)
Pin #87 - to Parking brake input wire on your radio (light green)
Pin # 87a - IGNORE. It isn't used in this case.
throw it in the dash, no switch or nothing
Edited by baggedon4s
99 suburban, ranger rover headlights, SS front bumper,roll pan with frenched tag, 2nd row delete,glassed dash..audio to come whenever I figure out what I want.
my pioneer hu i just took the green wire for the parking brake and gronded it with a switch inbetween. used a lamp switch rotor style under the dash cant see it. spin it two times and its on got a message gotta press on ok.
did not work by just grounding out.
~2006 chrysler Sebring~
~2 runs of 1/0 front to back~
~1/0 wire for "big 3"~
4 spl-hx 12'' dual 2
2 dtr 1.3400
3 c&d terminologies 1000s
100 aH Each
piccso 6.5 comps
pinoeer avh 4900dvd
pioneer xm box
blue gauges
custom dave the box guys box
new stuff on the way
Team
Soundstream
From the looks of it the light green wire on your unit needs to go to ground.
I don't have that headunit, but to bypass the parking brake on mine (jvc kd-avx1), I wrapped the wire around the antenna plug then put some tape on it to hold it in place. Works great.
Team Pinnacle / Team SouthEastSPL / Team SoundStream / Team GPI / GPI Sales Rep for Florida and Georgia
just ground the wire on a bolt under the dash works fine for me
98 Dodge Durango
12 000K 50/55W Headlights
12 000K 35W Fog lights
HU Panasonic CQ-VX100 7" Reciever
(1) Fi SSD 18" Fully Loaded
(1) Ported box 33hz
(1) Soundstream TRX1500D
(1) Soundstream TRX2.440
(1) RE 6.5" Component Set
(1) Rear battery
Big 3 in 0/1 gauge
2 runs of 1/0 Gauge wire
250A Alt soon..
