EXO Needs YOU! 18" Subwoofer Enclosure Design - Ascendant Audio Mayhem
EXOcontralto
no the box im making wasnt going to go to the ceiling u said u wanted a wall lol :o
Yeah I do want a wall, i was just confused why you need hieght measurements
The REAL YouTube Page
●▬▬▬▬★▬▬^๑۩۩๑^▬▬★▬▬▬▬●
Head Unit - Pioneer DEH-p6000ub
Equalizer - Soon To Come
Amplifiers - (4) Soundstream TX1.2600d's
Subwoofers - (2) Soundstream XXX 18's
Enclosure - 16 Cubic Foot Wall Tuned to 38hz
Power Wire - (200ft) Tsunami 0 Gauge PRO
BIG 3 w/ 8 C&D Batteries
Team DBs (Driven By sound)
He meant to just do a wall of mdf or whatever wood he will use, to kind of seal the back from the front to put some things in his back, have you watched the vid?
he says all he wants in the vid.
Oh I got ya. Not really looking at youtube today as my internet is sucking balls.
Either way with 2 18's and probably 2 3500's you are gonna have a ground pounder EXO.
¿ǝɯɐƃ ǝɥʇ
also don't forget, you want to use 58" wide, but the damn van tapers at the top, probably to like 50" or even less.
So dimensions you would want to use, unless your really good with wood working, and sneaking in a huge tight box in that van
I would concentrate more on the dimensions closer to the ceiling than the bottom.
Unless your going to lay the wood in play, and glass them to the contour of the van, and have a permanent non movable box
basically if you don't want something that is not permanent, make it to be able to go in and out of the door, or back area
I have seen way to many people do build logs, or try and do walls with the box outside, because its easy, and then try and wedge it in, and because of corners, or un expected contour of the vehicles interior, just being a big waste
I vote for a tline anyways though ;-)
Yeah, I just want to cut down the total amount of air space - I have WAY too much room! - I could easily cut that down by adding a wall from the rear tire wells - In the future, I will be able to mod, and add subs as needed in that amount of space, I HOPE
My plans are to add another sub in like six months - I will make it look like a single chamer with some fiberglass
What's a Tline? - And you're right! - I should proably measure the top aswell! - I will be right back!
Watch my build log in my sig (look at my youtube:Kirill007), it's a type of enclosure's which is very efficient, and has really accurate bass.
Get's very loud of not that much power, but lower's the power handling of the sub.
It's basicly one long port which has a certain lenght and whre the port area of the port should be around the sd(= cone area of the sub measuerd in sq inches) or 80% of it's sd.
I sent you an email. Overall design is 46" wide x 28.5" tall x 32" deep
If you want to do a full wall, this box will not work. It is subs up, port rear.
It can be adjusted for subs and ports on one side with minimal changes.
This design is 32" deep, and the port is 21" deep.
If you want lower tuning (30-31 Hz), make the box just as I sent you, but 34" deep instead of 32" and the port 25" long instead of 21".
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="660" height="525"></embed></object>">
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="660" height="525"></embed></object>" type="application/x-shockwave-flash" width="425" height="350">
THANK YOU!
<a href="http://s634.photobucket.com/albums/uu69/exocontralto/?action=view&current=box1.jpg" target="_blank"><img src="http://i634.photobucket.com/albums/uu69/exocontralto/box1.jpg" border="0" alt="car audio"></a>
This is sweet, but Is there a way I could to do each induvidaully as a unit, so I can make the other one later? -
  • Who's Online   0 Members, 0 Anonymous, 580 Guests (See full list)
