Thnx guys.
ALL I can take credit for is what goes into it, the build and whatnot.
Law does have a dope ride tho, Nice and clean, sexy Body kit n such, & the HID's are NICE too.
More to come as I have time to build it.
As Dozier pointed out, this one AND the truck.
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
So a friend has this old junk layin around and figg'd no one would have more/better use for it than me.
Posted Image
Ok. Problem was, the sh*t was so old the cap was sealed on permenantly.
So....SHAZZAM! Nothin a hammer and chisel won't fix.
Posted Image
And there's exactly THIS much left.
Posted Image
So I got to thinkin bout where it could go...
Posted Image
Posted Image
No "MEADE 45'S", just sealin it up and addin a lil to the inside.
I wouldn't use that stuff for actual "real" glass work, but in this case i guess its coo for sealer.
Posted Image
Posted Image
Posted Image
Posted Image
Here you can see how I filled in almost all the screw heads. It's gettin vinyled anyhoo but I just like a smooth box to start with rather than all those lil dents.
Posted Image
Thats all for now folks. More as it happens.
Thnx man.
Still kinda fug right now IMO.
Once its vinyled and behind a plexi window, it should be pretty sexy.
Thnx Bibby.
When it's done it should be a pretty nice setup IMO.
The trunk will be sealed off w/ room around the sides of the box for bass to get funnelled into the cabin with the seats down and thru the rear deck which will get opened up.
Vinyl/plexi, neon lights, should be sexy.
Stay tuned.
when people do vinyl, do they put that directly on the box, or do they use a padding? i think if you use a padding, itll feel cool, and cover up the inperfections better
I use poly-chloride, Marine/outdoor vinyl from Jo-Ann's or Hancock fabrics.
I think for the Truck box I'mma hit up my bro who works for an audio shop and see what he can get me to color match the tan interior. If that doesn't pan out, I'll take Ray's advice and call Mr.Meade and see if I can get some via Ray's account w/ Keystone.
This box will be covered in white vinyl and the outer "enclosure" will be done in trunk-color matched charcoal carpet.
I have done both with and without padding. Depends on the application. Some folks don't like the lower trim pieces in my trunk,the part over the vertical firing subs because it's got 1/2" foam to cushin it, and vinyled over that.
In MOST cases, NOT using faom under your vinyl will not cause any imperfections to show unless they are major imperfections or actual undulations in Fglass or other material. In the Black 300zx, I used Headliner material under the vinyl for a slight (1/8") amount of padding, but on the trim pieces in my trunk around the horizonally firing subs it's just vinyl over mdf.
Hope that helps.
  • Who's Online   0 Members, 0 Anonymous, 2533 Guests (See full list)
